There are a couple of good ones for the $200 ones, but I'm not going to say because i might want one of them soon myself :(
**** those custom ones.. $2k for plates it the biggest joke in the history of driving. Only for people with too much money, not for plebs.
https://www.sau.com.au/forums/topic/33042-ideas-for-plates/#findComment-663621
If you like your car to look the part.....polish....paint...carbon etc.
Finish the car off and buy a set of plates????? (people alway notice your plates)
$2000 is cheap and you can alway resell and get your money back...if not more.
But choose a plate tag, that others will want....(names are not a good idea, resale market very limited and you will lose your money)
Consider it as an investment...putting your money in a bank for another day....but enjoying it at the same time.
Older boys toy....Boys and their toys...cars are just toys to play with and enjoy....enjoy life buy a better toy (well thats the theme I went for..for fun and investment)
I have:
TOYS on my STI
NO TOY on my GTR
A TOY this plate will go to Auction
NSX 666 was on my Black NSX. These plates are for sale $750
95 GTR was on the the other 1995 GTR v-spec. These plates are for sale.$1000
Can anyone here suggest any good car clubs that meet regularly.
thanks Phillip
https://www.sau.com.au/forums/topic/33042-ideas-for-plates/#findComment-663908
Well since I'll never be able to afford what I want, and since it is still available, what about ILCUL8R "I'll see you later" but then again if I did have $2000 sitting around I definatly would not be spending it on plates, so many mods so little cash! :(
https://www.sau.com.au/forums/topic/33042-ideas-for-plates/#findComment-663945
thats the line - i guess if you're a certain type of person and has lots of money to throw around.. i could'n't really give a flog what plates a car has on as long as it looks the part..
horses for courses.. I can think how much $2k invested at 7% p.a. in 5 years will probably be worth more than a little plate.
https://www.sau.com.au/forums/topic/33042-ideas-for-plates/#findComment-663949
Well since I'll never be able to afford what I want, and since it is still available, what about ILCUL8R "I'll see you later" but then again if I did have $2000 sitting around I definatly would not be spending it on plates, so many mods so little cash! :)
MAN I LOVE IT
and i was about to type a message asking if i could use it.
but its too many letters
**Step 4 Enter your Alphanumeric Combination:
Prestige Plates require an Alphanumeric combination of 3 to 6 characters.**
:D
https://www.sau.com.au/forums/topic/33042-ideas-for-plates/#findComment-664765
MELV
Yes that was me...you were a couple of lanes over....like the rear wing and the look of your car. Looks and sounds like you've just completed a few upgrades.
Worth going to ASPLEY just to have a closer look at your car.....talk to you then.
As I said, I purchased NO TOY for the GTR, but was contemplating getting SHOW ME, which was also available. Show Me makes a number of statements....good show circuit....good for tuff street car....or for seeing more than you should??? Good plate for the all round car. You would never lose your money and will make more than a pissie 7% return.
Let me know what you eventually get.
Talk to you latter Phillip.
p.s. PREDATOR are you still after the new UA copy 400R side skirts....if so you can have them for $100 a piece.
https://www.sau.com.au/forums/topic/33042-ideas-for-plates/#findComment-665087
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
