Hey guys. dont really know if this is the path i wanna take but just throwing it out there to see if there are any takers/interests. i have built this car from pretty much ground up doing pretty much everything to this car myself other than tune it. I dont really wanna sell it as soooooo much hard work has gone into it, but i need to sort some other things out and have a wedding to pay for! just sorta throwing it out there atm to see if its worth selling. anyways here is a list of things done
ENGINE BAY/DRIVELINE:
RB25det
ROSS forged pistons
ARGO "MASSIVE" rods
ARP main's, conrods, head studs
head full recon
brand new nissan rb25 oil pump
all nissan seals/gaskets
ACL metal head gasket
ROLLMASTER adjustable cam gears
GARRETT GT3076 turbo
6boost exhaust manifold
greddy inlet manifold (copy only)
50mm external gate
Custom tubular upper rad support
Alloy radiator with AU thermo fans
BTR alloy overflow
BTR alloy oil catch can
GREX/TRUST oil relocation/cooler kit with thermostat
ORC twin plate clutch
RB25DET geabox
custom tailshaft
locked 4.3 diff
SUSPENSION:
Near new ISC coilvers (bought june ish last year. only done 5 or 6 mallala days from brand new)
SPL caster rods, traction arms, camber arms, toe arms
IKEYA FORMULA tie rods not installed but will come with the car
INTERIOR:
Custom dash with VDO 200kph, fuel, water temp gauge's
oil temp, oil pressure and boost gauge's in stereo position.
Monster tacho
OMP fixed back seat
Padded bolt in half cage
EXTERIOR:
Custom Purple paint
VIVA full kit
VIVA vented bonnet
VIVA boot lip/duck tail
GRAMLIGHT pro57's titanium lip 17x9's all round
J's headlights
Fuel system:
Walbro in tank pump
custom surge tank
bosch 044 external engine feed pump
95% of the wiring has been hidden, only thing left to do was to re-locate fuse box and all wiring to it.
last tune made 260rwkw on 13psi running E10 100 octane pump fuel
im looking at offers around $16k. i know some ppl are gonna say im dreaming on the cash but if i dont get what i want then its not worth me selling it. so no time wasters or bullshit posts pls! GENUINE interests only
contact me on 0413595838 or via pm
https://www.sau.com.au/forums/topic/330422-s13-track-car/
nah man, will turn it back into a street car before i thought about pulling it apart!!!
You might have better luck selling it for more after turning it back into a streeter.... GL with the sale any way, f**king love gram lights. Win.
https://www.sau.com.au/forums/topic/330422-s13-track-car/#findComment-5376107
if anyone else whats to know details on engine (other than you beej who has no interest in the car) call morpowa and ask for Josh as he is the one that built motor... motor has prob only done about 10 drift days roughly???
https://www.sau.com.au/forums/topic/330422-s13-track-car/#findComment-5385269
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
