I got rid of the nasty flat spot !!!
I don't know how for sure, but read on.......
After a recent round of simple mods, I took the car in to see if everything was on track and OK.
Just a bit of background.
Used same dyno. First (lower) run don in winter on a 16 degree day, second was done on a 32-33 degree day. Dyno was run in NON shootout mode, in 4th gear.
Difference between first run and second run was a highflow cat, an adjustable exh cam gear set at 3 degrees retarded, and a different rear muffler.
Plus the ECU was out of the car for a day prior, so it would have reset itself.
Full mods are very simple, 3 inch turbo back exhaust, 12psi boost (see attached sheet) highflow panel filter in stock box, FMIC, adj exh cam gear. Stock ECU, Stock turbo.
The thing I am most happy with is that for reasons unknown I have got rid of the flat spot that most other R33 GTS-t's get. I'm still running the same ECU... The only thing I can see is maybe (and it's a big maybe) it was cause the ECU was reset the night before..
Getting rid of the flatspot has gained me about 35rwkw in the mid range !!!! VERY happy with that.... Up top it's about 10rwkw gained, but it's much smoother.
I might wind the boost up a little cause it's dropping off at the top (see attached) due to the wastegate creeping open at high RPM's.....
The next step for me is programmable ECU.. :P
Open to comments :D
Anyway, too much crapping on, have a look for yourself....
https://www.sau.com.au/forums/topic/33043-dyno-run-interesting-results/
  • Replies 51
I was actually pretty happy with the A/F ratios on the second run (the green line).
They stick to 12:1 which is just about perfect, then drop to about 11.2:1 after about 4500rpm.
I could get a SAFC to lean it up above 4500rpm, but there wouldn't be much in it. I think there would be bigger gains in being more aggressive in the timing. But sadly we don't have much control (almost zero control) over the timing.
I did adjust the base timing from 15 degrees to 17 degrees and there was absolutley no difference in the runs which supprised me..... Maybe I should've gone to 20 degrees or something ??
J
What sorta power were you making before these mods ?
You know, that giant flat spot looked exactly the same on my SR20DET. Im pretty sure it was because the ECU was pulling timing at that particular point. After a ECU reset and resetting the timing, it never came back again...
Also that extra power came mostly from the leaner AFRs I believe.
Oh btw, you Skyline guys must have quite a shorter diff and 4th gear. On the rollers, my car goes pretty close to 165kmh in 3rd gear!!!!!!!!!!!
Hmm If i put a skyline diff in my car... *GRIN*
Steve - Yepp, I think your right, better flowing uptop is helping things.
Busky2k - I'm supprised that a reset got rid of the flat spot !! If it comes back again you know what I'll be doing :D BTW: 2nd gear goes to ~105km/h, 3rd gear only goes to ~140km/h, and 4th tops out just before 180km/h, so the gearing is fairly close...
RB20LagWagon, the S14 is definitely not 4.1 dood.
The auspec workshop manual clearly states its 3.692 to be precise! Perhaps the JSpec ones are 4.1?!
Jay95R33, what are the ratios of your gearbox? I'll state what the S14 one is;
1st- 3.32 (~65kmh)
2nd- 1.90 (~113 kmh)
3rd- 1.31 (~ 163 kmh, everyone ive dragged always shift into 4th way before I do)
4th- 1.00 (no idea, never gone that far, but it hits the limiter on the dyno)
A skyline diff would do wonders on the strip in this car I reckon....
Btw, Im suprised a reset worked aswell, but I also reset the timing at the same time, as it was like 5 deg overadvanced. I think that was what really fixed it. Btw, I believe you have to disconnect the TPS during idle to get the true base timing.
Not sure on the gearbox ratios for a R33 GTS-t. If it helps any I've got a stock gearbox and the diff runs the stock 4.11 ratio.
Hmm, the first run I did yesterday with my old ECU didn't have the dip, and that was before we advanced the timing to 17 degrees. So in my case I think it may have been just the reset that got rid of the dip... Not sure...
Wierd how advancing the timing did nothing. The CAS is definatly rotated more than it was before, and at idle it showed the increase in base timing, just didn't do anything on the dyno run...
At 15 degrees and 17 degrees the two power lines were sitting right over each other.
I suppose that it's good that the car can pull off a few full power runs and not loose even 1rwkw :D:D Nice and consistant power, even on a 33 degree day ! :D
J
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
