  • Replies 51
I've never seen a flat spot THAT bad on an R33 with stock ECU.
I've seen many small dips before, but nothing that severe!
Maybe your ECU was just really having a bad day!
Having a total shocker of a day !!
But now it's mega smooth.
For a stock ECU I'm really happy at how smooth it is now.
There's a bit of a dip right up top where the wastegate is having a hard time, but apart from that it's all good.
If I'm real keen I could squeeze another 1-1.5 psi out of it, then run it again on a cold day and maybe break 175rwkw on the stock ECU.... Or run it in shootout mode and it'll read higher.....If I'm really keen that is, which I'm not...
Just as a comparison on the dyno - A R32 GTR ran up straight after I did, this GTR did 240rwkw on a dyno down in Melb, and only pulled 225rwkw on this dyno. This same car has managed a 4.1 sec 0-100 time !!!
Just goes to show that you can't compare different dynos etc...
J
u sure the speedo isnt out of whack? the speedos are known to be out of whack alittle at those speeds, because my speedos seems to reading like 190km, but im in 5th gear and at 5k rpm, and hit the 180km/h speed cut.
Al,
I used a car speed estimator table that uses g'box ratio, diff ratio, & wheel/tyre circumference. It spat out 204.12km/h @ 7000rpm in 4th. This is using a 255/40/17 tyre size.
nightmare5,
According to the same car speed estimator I mentioned above, the speed in 5th at 5,000rpm will be 193.88km/h. The limiter (usually ~180-190km/h) would be pretty much at those rev's!
6,500rpm in 5th is 252km/h
7,000rpm in 5th (if you have enough power & tarmac to get close to those rev's) is ~271km/h
J,
So you can confirm how accurate my Car Speed Calulator vs. your actual reading is I'll give you the CSC reading for 3,000rpm 4th gear - The CSC suggests that on 225/50/16's you "should" be doing 86.87km/h in 4th @ 3,000rpm.
Let me know what you get mate.
G'day JAY
I might wind the boost up a little cause it's dropping off at the top (see attached) due to the wastegate creeping open at high RPM's.....
More boost will probulary induce more wastegate creep and give same result.
Invest in a HKS electronic boost controller and wastegate actuator, it's one of the best mods to a stock turbo system to improve boost response and will help hold boost higher in the rev range. The only llimiting factor will be the turbo but it should be able to produce 13psi all day safley till redline.
I also agree there's more power to be had with a leaner setting in the top end but this way she'll be safe from detonation.
Cheers
Nick
Yeah good call mate I have lost the plot haven't I :D Doh! I have drag on the brain. Of course aerodynamic drag will not change the result of diff, g'box & tyre size speed calculation. I dunno' what I was thinking about there?
Drag will however make it harder for a car to reach it potential maximum top speed.
Yeah, I think your right there.
I was thinking about upgrading the wastegate to a 13psi one (if they come in that rating), but I think you have to pull the turbo out to replace the actualtor :D A bit of a pain in the butt for a small improvement :)
Do you think a EBC (without using a upgraded actuator) would help reduce the boost drop off ?
J
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
