  • Replies 51
The speeds etc look right.
Mine is the same.
On 12.5psi I made 152rwkw on RPM's Dyno then 15psi made 164rwkw (turbo runs out of puff). Turbo's differe and give you a rough idea. You could be making +10-15rwkw.
Jay95R33.
If you are getting boost drop no matter what you bump it up to you will always drop to that same psi up top. Get your self an RB20t wastegate that is a little stronger (10-11psi stock). UNLESS you get your self a good EBC that learn's the boost curve and can adjust the solanoids on the fly to make it hold boost. I.e Blitz SBC-ID & AVCR.
You don't have to remove the turbo to replace the actuator.
Why buy an aftermarket actuator?? All you have to do is install a coupla washers onto the mounting points of the stock actuator and this automatically puts more pressure onto the wastegate flap!
I put 2 washers on each, and this raised the boost by 3psi from stock! Good value for 20c compared to a few hundred $$$. Less spiking from the bleeder too, since it now had to bleed substatially less boost to get the same result.
Cool - thanks Joel. I never thought of that !! So the RB20 turbo's have the same actuator (but diff spring rates)?
Busky2k - I'm not a big fan of dodging up the actuator. Seen a few people play with them like bending it and putting extra springs on, but they are never the same.
J
  • 1 year later...
SDEWY5,
That would be because you are not mechanically inclined.
The washer, elongated holes or adjustable rods work fine.
In fact the washer or the rest would be more reliable, at least you know its not going to jam or bugger up.
Whats with the 2004 post revival?? haha :D
  • 2 years later...
  • 4 weeks later...
is there any reason why this is in the forced induction quick ref guide, there is no real help here unless i missed something, some one had a flat spot and does not know how he fixed it, what help is that?
there is also a lot of reference to a dyno graph that is no longer here.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
