Hey Guys,
Just decided to try and clean out my garage in hope of fitting a car back in there one of these days. Below are pictures of each of the items; feel free to ask any questions. I can be contacted via PM, I'm on here most days and will generally reply fairly quickly. Feel free to make offers, you never know!
R33 Genuine Nissan Underbody Plastic - First one i've seen - $40
R33 Standard Front and Rear Swaybars (with rubbers) - $40 for both or $25 each
R33 Open 6 Bolt R200 Diff (4.11 Ratio) - $60
R33 Drive Shafts (6 Bolt to suit above diff) - $40 for both
R33 Washer Bottle (unsure if motors work) - $15
R33 Series 2 Passenger Light (needs to be resealed, cover was taken off for cleaning. Plastic cover has small crack, not visible from front.) - $80
Apexi Boost Gauge 60mm (Fake?) - $30
R33 Stock Suspension Front and Rear (Average Condition) - $50 for all of it
Diff Back Exhaust (Good for Compliance) - $40
R33 Standard Dump / Front Pipe - $30
Standard RB25DET Cams - $40
R33 Maroon Boot Lid (No Spoiler, Lock or Hinges) - $30
T Sport Boost Gauge 52mm (All wiring and boost line Included) - $40
R33 Series 1 Manual ECU - $60
6 x R33 Series 2 Coilpacks (All working when removed) - $80
6 x Splitfire R33 Coilpacks (Perfect Working Order) - $400
Pod filter Adaptor (Suit Standard afm?) - $15
Custom PWR Radiator (Thick core, looks mint) - $450
Decided to stick with my standard radiator. Side panels make it easy to mount. Comes with Thermo Fan as shown in pictures. Dimensions of the Radiator are 400 High, 550 Wide to Sidetanks, 700 Wide to Panels and around 60 Thick as pictured. - ON HOLD PENDING PAYMENT
All of the parts can be picked up from the Gold Coast (Robina Area) or I can post at buyers expense.
Mic
Updated List
Bumpity
Items that are still here
6 x SPLITFIRE R33 Coilpacks (Perfect Working Order) - $400
Pod filter Adaptor (Suit Standard afm?) - $15 -
PM me with any questions or offers
hey mate i cant send pms as i gotta send more then 10 post here for some reason
I am really interested on your underneath plastic cover for my r33 S2.
Im about 10 mins away from robina.
please gimme a sms 0408183420 and will pick up asap.
Cheers
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
    • Nothing photo worthy since last update, lots of little plumbing bits for the AAC/Cold start valves, and unfortunately I still need another couple of parts for the brake booster line and the AAC into the plenum. Otherwise it all looks good to start up engine wise, onto checking the electrics/interior
