its meant to flick back and forth under light load when its in closed loop then hold on rich when you nail it. gets a little annoying when cruising around and it keeps moving....
Im not 100% sure how skylines work lol but my xr6t stay at 13-14 all the time at idle, but still when he guns it it dose the same thing, just not as bad
https://www.sau.com.au/forums/topic/330456-r33-airfuel/#findComment-5367474
haha yea i noticed ehy i thought i got mine at a nice discount first off talked ehm down from 200-150 then last minute said oh i have a 20% off card from entertainment so got it for 125. yeah im guessing your boost guage also goes from -18( my skyline ) and then a bit of throttle bam up to 1 and upwards
https://www.sau.com.au/forums/topic/330456-r33-airfuel/#findComment-5367483
Seems a bit dumb to add when you're just gonna have to remove it whenever the popo sends you off to Regency :)
i duno y he dose it there in plain sight to, he has had the car for just over a year and its been through regency 4 or 5 times now, p plates + skyline = regency lol
https://www.sau.com.au/forums/topic/330456-r33-airfuel/#findComment-5367485
i got the entertainment 20% off thing to ahahah
i want them for my xr6 but got to fix the trans 1st
cmon tax money lol
https://www.sau.com.au/forums/topic/330456-r33-airfuel/#findComment-5367488
haha hav u got the shitty 4speed which dies? my mates pushing 360rwkw on the 4speed its been due to blow for a few months now lol it crunchs and everything do u hav to do that shitty 2-3grand gearbox thing at all???
unless u have manny
https://www.sau.com.au/forums/topic/330456-r33-airfuel/#findComment-5367493
unless u have manny
yup good old 4 speed auto week as crap
its costing me $2500 to be rebuilt n beefed up and if i have the cash a 4 grand stally :)
cant wait
https://www.sau.com.au/forums/topic/330456-r33-airfuel/#findComment-5367497
u know the percet zf 6speed auto goes for less than 2500 and can handle any power u put through it and changes faster than any manual. just a thought.
u should get some 3.7's diff gears or at max 3.9's they help fords like a mofo
https://www.sau.com.au/forums/topic/330456-r33-airfuel/#findComment-5367507
if i could i would put a zf in my car but its like a massive job and pricey job to....around 10 grand all up
https://www.sau.com.au/forums/topic/330456-r33-airfuel/#findComment-5367513
u can pick up the unit its self if u wait around for 1grand and i think the ba's still had enough room to fit the bastard in so not alot of modding otherwise if its cut out for the tiny 4speed then yeah big job but it will make the ratio of your gearbox more competative whith those of holdens and what not( holdens and there 1stgear) 4speed has bad as ratio unless your boost comes on early u will need them diff gears or stally
you should speak to henrich performance and tunning cheap and does the best work he got my na 6 to beat stock ba xr6t's he only charges labour never on the part its self, and he dyno tunes everything until he thinks its perfect
hes at lonsdale btw
https://www.sau.com.au/forums/topic/330456-r33-airfuel/#findComment-5367520
narrow-band sensor? whats that :)
Could it be a stuffed sensor?
Narrow band sensor is the normal O2 sensor that connects to the ecu. Any afr guage connected to it is just for show - to make it work properly you need a wide band sensor.
https://www.sau.com.au/forums/topic/330456-r33-airfuel/#findComment-5367596
it's because you are watching a narrow band 02 sensor and the guage is referencing that
the stanard 02 sensor is is narrow which means slow and narrow, ie it only focuses around the 14.7 range and can't do anything meaningful outside that range
this is why it goes spazzo and is all over the place. the stock ecu uses this sensor as a "guide" only to save fuel and trim the inj during cruise (ie plodding along at 100km/h)
a wideband 02 sensor is a fast and wide sensor and can sweep all the way through quickly and show meaningful values
so to get your guage showing anything useful you need a wideband 02 sensor. the sensor itself is about $150 and is of no use, other than to tune your car with a standalone ECU and show true AF/R on a AF/R guage. ie you wont get any benefit if you have stock ECU
https://www.sau.com.au/forums/topic/330456-r33-airfuel/#findComment-5367673
hes at lonsdale btw
thats who i go to bruce and he told me its to hard of a job becuase u got to change the looms ect lol
https://www.sau.com.au/forums/topic/330456-r33-airfuel/#findComment-5368797
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
