you mean a Maloo? SS = commodore, Maloo is the HSV one with 317kw.
Also, agreed on the xr6T, yeah they are reasonably quick but you can't just wind up the boost and go for it. Injectors run out pretty quickly, and some internals can't really cope with big power. waste of such a monster turbo really
  • Replies 55
comparable to an XR6 or a V6 commonwhore etc........in std trim.
when modded up and pumping out +220rwkw then its comparable to a 2000ish V8 from just about anyone [possibly excepting ferrari Lambo style]
at +250 it is comparable to a 2010 V8 from Falcon or Holden.
It is not really combarable to a GTR, evo or STi etc because they are 4wd, but they do cross paths now and then and it is all a question of driver skill/outright power/and application [drags/circuit/drift etc] as to which one is best.
Your really asking too much - and if you hang around here or search you will find plenty of skyline vs the rest type of threads with countless arguments about who is best and why.
Who really cares, only each individual owner, because on an open road sitting on 100km/h they are all the same........
I have dragged a EA falcon (one of the fastest Falcons_ and a VP Commodore (fastest v6 Commodore) against an unmodified GTS-T and got utterly DESTROYED. Like others said they are comparable to the BA XR6 Turbo or VT-VZ LS1 Commodores, although 9 times out of 10 a VY SS Auto will trounce a manual GTS-T because most people cant drive for shit and Commodores are much easier to drive for average drivers. I'd know i'm an average driver. A current VE SS will beat a perfectly launched stock GTS-T but even a badly launched FG XR6T will easily beat a stock GTS-T.
Edited by FrangaR33
but the system has a pressure sensor on it and when a certain pressure is reached the system fails and A-LSD gives up (light on the dash) this means it wont ever run the pump again by itself until you reboot the car. driving with the pump running non-stop is Ok and no major issues that i've seen, but on my car it still single span even with pump %100 running. it seems to require a proper bleed and check of the system regulary to make it work. when you do that, it works awesome
How long does it take for the pressure to build up to that error point with the ALSD running at 100%?
Yeah I try and bleed mine every few months nowadays, it's probably my tyres that are letting me down now.
It's a hard comparison - larger engine capacity will always have the advantage for "easy" power regarless if n/a or turbo.....
By "easy" power - I mean, any mods you make to a larger capacity engine will see more gains.
PM-R33 if you hard run the pump for about 5 seconds it will fail as it must have a pressure trigger
i can run the pump for 2 seoncds, turn it off, repeat and do this continously and its fine
its only when you leave it on for about 5 seconds that it has a hissy fit
you could hook up a system to make it run the pump for 2 seconds, turn off, 2 sec, off and repeat for ever and it would probably be fine
Ok cheers Paul I will have to have a play around with the setup once the Vipec comes. I just want that rear diff locking as best as it can and preferably prior to breaking traction.
Edited by PM-R33
it's a normal diff as far as i know
i had diff place pull mine apart as i asked them to dismantle and fix it
and they said there is nothing they could fix (ie it wasnt broken)
they said they could put a new kaz centre in it no problems, but at 1200 no thanks
racepace have said they can shim it but in the vspec diff there is very limited room
not sure but maybe he (racepace) has shimmed vspec differs in GTR's before (not GTST)
as they do tons of track GTRs and no doubt a lot of them would be vspec's with possibly std diff's
yeah i can run my pump all day and night
it still doesnt guarantee lock
i think the issue is air in the lines or bleeding issue
if i do the bike pump trick as noel said it seems to clear out the demons
and when it locks (i test it in the wet sometimes) the diff is amazing
if you could rig up a way to auto bleed that would be ok
FYI i've ran against a 317 UTE on a private road upto 180km/h and neither of us could pull away
pretty sure it was a SS R8 Ute new model
Lots of private roads in Oz, RTA hardly have anything to do these days.........
And OP, see what I mean about opinions being everywhere, some say you can and others say you cannot do blah blah, driver car conditions nerve situation all give different results
Bring on the STIG
A 250rwkw Skyline will flog a standard XR6T (my mate has a sedan), hell my mates standard turbo Supra pulls away from it. I've raced a 300+rwkw BA XR6T sedan and it was fairly even. They really aren't as fast as people make them out to be, they are fairly heavy and the utes have worse traction problems than Skylines have. But yeah, they do make good power very, very easily. But what do you expect from a 4L GT35?
That's one thing I really want to do to my car over the next few years is to setup up the suspension/tyre/diff combination for a hell of a lot more traction as to me this is the Achilles Heel to most GTSTs with power.
as it should ba xr6t has 180rwkw stock and like people said massive diff gears and heavy my mates running 360rwkw good for mid 11's with just the engine stuff done auto, non slicks tyres. no other mods basically( other than engine) so yes they are as fast as people say they are hes curently beating 450rwkw s/c vx clubby
if you have been in an areoplan then you have been in a 350rwkw+ xr6t they have something like 1200nm of torque
It depends on which model XR6T, the new XR6Ts are making 240-260rwkw standard! Injectors and a tune are not exactly the hardest modification. The engine internals have been fine since the first model or two.
Better then a skyline that you are forced to change/hi flow the turbo to get any serious power! Brings in all sorts of legal issues etc.
ages ago at a dyno day we dynoed a brand new bog stock XR6T ute mark II or series II which ever it was and it made 209rwkw
6 speed manual turbo ute
it would have been about 4/5 years ago now
Yup that would be about right. BA's were roughly 180, BFs around 200-220, but the FGs I have seen are around 240-260rwkw.
Exactly. And with their terrible depreciation they'll be worth $20k in 5 years and an absolute bargain family car with some fun for Daddy. :-P
My boss has a stock RS4 stagea and raced a XR6 around windy roads. He recons it would creep on him on the straights but it was no match for his four wheel drive around the bends. He didn't know what year it was but he thought it was a new one
And that is a 1620kg wagon with and RB25Det in it LOL. My gtst is quicker than it being 200kg lighter.
Then again the XR6 may not have been trying too hard lol.
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 馃槄
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 馃珷
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
