you mean a Maloo? SS = commodore, Maloo is the HSV one with 317kw.
Also, agreed on the xr6T, yeah they are reasonably quick but you can't just wind up the boost and go for it. Injectors run out pretty quickly, and some internals can't really cope with big power. waste of such a monster turbo really
  • Replies 55
comparable to an XR6 or a V6 commonwhore etc........in std trim.
when modded up and pumping out +220rwkw then its comparable to a 2000ish V8 from just about anyone [possibly excepting ferrari Lambo style]
at +250 it is comparable to a 2010 V8 from Falcon or Holden.
It is not really combarable to a GTR, evo or STi etc because they are 4wd, but they do cross paths now and then and it is all a question of driver skill/outright power/and application [drags/circuit/drift etc] as to which one is best.
Your really asking too much - and if you hang around here or search you will find plenty of skyline vs the rest type of threads with countless arguments about who is best and why.
Who really cares, only each individual owner, because on an open road sitting on 100km/h they are all the same........
I have dragged a EA falcon (one of the fastest Falcons_ and a VP Commodore (fastest v6 Commodore) against an unmodified GTS-T and got utterly DESTROYED. Like others said they are comparable to the BA XR6 Turbo or VT-VZ LS1 Commodores, although 9 times out of 10 a VY SS Auto will trounce a manual GTS-T because most people cant drive for shit and Commodores are much easier to drive for average drivers. I'd know i'm an average driver. A current VE SS will beat a perfectly launched stock GTS-T but even a badly launched FG XR6T will easily beat a stock GTS-T.
Edited by FrangaR33
but the system has a pressure sensor on it and when a certain pressure is reached the system fails and A-LSD gives up (light on the dash) this means it wont ever run the pump again by itself until you reboot the car. driving with the pump running non-stop is Ok and no major issues that i've seen, but on my car it still single span even with pump %100 running. it seems to require a proper bleed and check of the system regulary to make it work. when you do that, it works awesome
How long does it take for the pressure to build up to that error point with the ALSD running at 100%?
Yeah I try and bleed mine every few months nowadays, it's probably my tyres that are letting me down now.
It's a hard comparison - larger engine capacity will always have the advantage for "easy" power regarless if n/a or turbo.....
By "easy" power - I mean, any mods you make to a larger capacity engine will see more gains.
PM-R33 if you hard run the pump for about 5 seconds it will fail as it must have a pressure trigger
i can run the pump for 2 seoncds, turn it off, repeat and do this continously and its fine
its only when you leave it on for about 5 seconds that it has a hissy fit
you could hook up a system to make it run the pump for 2 seconds, turn off, 2 sec, off and repeat for ever and it would probably be fine
Ok cheers Paul I will have to have a play around with the setup once the Vipec comes. I just want that rear diff locking as best as it can and preferably prior to breaking traction.
Edited by PM-R33
it's a normal diff as far as i know
i had diff place pull mine apart as i asked them to dismantle and fix it
and they said there is nothing they could fix (ie it wasnt broken)
they said they could put a new kaz centre in it no problems, but at 1200 no thanks
racepace have said they can shim it but in the vspec diff there is very limited room
not sure but maybe he (racepace) has shimmed vspec differs in GTR's before (not GTST)
as they do tons of track GTRs and no doubt a lot of them would be vspec's with possibly std diff's
yeah i can run my pump all day and night
it still doesnt guarantee lock
i think the issue is air in the lines or bleeding issue
if i do the bike pump trick as noel said it seems to clear out the demons
and when it locks (i test it in the wet sometimes) the diff is amazing
if you could rig up a way to auto bleed that would be ok
FYI i've ran against a 317 UTE on a private road upto 180km/h and neither of us could pull away
pretty sure it was a SS R8 Ute new model
Lots of private roads in Oz, RTA hardly have anything to do these days.........
And OP, see what I mean about opinions being everywhere, some say you can and others say you cannot do blah blah, driver car conditions nerve situation all give different results
Bring on the STIG
A 250rwkw Skyline will flog a standard XR6T (my mate has a sedan), hell my mates standard turbo Supra pulls away from it. I've raced a 300+rwkw BA XR6T sedan and it was fairly even. They really aren't as fast as people make them out to be, they are fairly heavy and the utes have worse traction problems than Skylines have. But yeah, they do make good power very, very easily. But what do you expect from a 4L GT35?
That's one thing I really want to do to my car over the next few years is to setup up the suspension/tyre/diff combination for a hell of a lot more traction as to me this is the Achilles Heel to most GTSTs with power.
as it should ba xr6t has 180rwkw stock and like people said massive diff gears and heavy my mates running 360rwkw good for mid 11's with just the engine stuff done auto, non slicks tyres. no other mods basically( other than engine) so yes they are as fast as people say they are hes curently beating 450rwkw s/c vx clubby
if you have been in an areoplan then you have been in a 350rwkw+ xr6t they have something like 1200nm of torque
It depends on which model XR6T, the new XR6Ts are making 240-260rwkw standard! Injectors and a tune are not exactly the hardest modification. The engine internals have been fine since the first model or two.
Better then a skyline that you are forced to change/hi flow the turbo to get any serious power! Brings in all sorts of legal issues etc.
ages ago at a dyno day we dynoed a brand new bog stock XR6T ute mark II or series II which ever it was and it made 209rwkw
6 speed manual turbo ute
it would have been about 4/5 years ago now
Yup that would be about right. BA's were roughly 180, BFs around 200-220, but the FGs I have seen are around 240-260rwkw.
Exactly. And with their terrible depreciation they'll be worth $20k in 5 years and an absolute bargain family car with some fun for Daddy. :-P
My boss has a stock RS4 stagea and raced a XR6 around windy roads. He recons it would creep on him on the straights but it was no match for his four wheel drive around the bends. He didn't know what year it was but he thought it was a new one
And that is a 1620kg wagon with and RB25Det in it LOL. My gtst is quicker than it being 200kg lighter.
Then again the XR6 may not have been trying too hard lol.
    • All the best with it mate. Hopefully no dramas. I found quite a few issues when i pulled mine out eg fkt trans and engine mounts, throwout bearing, i had not been aware of, so 'any car maint' can be worthwhile it seems.
    • I think it's the alternator, there's some cracked shit going on with the rectifier. But so far, seems to be fine again? No sparks, no weird arcing when the leads went on. I ran this past a mate, he said he had similar issues before and his auto sparky replaced the alternator. All I know is, car works, car not on fire lol.
    • Brother-in-law's workshop. And I'll be doing. Family doesn't get priority over long running customer jobs. It wouldn't normally take so long to get to a task of mine, but there was a series of unfortunate events involving the dyno (blowing it up) that caused a serious backlog in the normal workload, that has toaken literally forever to get out from underneath. I can't do, or more to the point, choose not to do, jobs at home that require tools I don't have or would leave me without my daily if something goes wrong that thwarts me. Gearbox out on the floor with chassis stands is not palatable when I can use a hoist at the shop. But I've only had the box for a few weeks. It's the injectors and AFM that have been waiting on access to the dyno.
    • Thanks for mentioning it on the forums! Much appreciated Jen and I likely can't make it this weekend, but looking forward to see what you folks cook up in the future. Enjoy!
    • Welp, I have been driving it around (a bit) and messing with idle and return to idle characteristics. This is all well and good until I discovered my starter motor... is nearly dead. This is unfortunately after I booked my exhaust and tune in. This is the new section of my exhaust, after losing my mind with vbands and clamps. Yes I now have 4 mufflers. The two middle ones are 5in body 3in pipe round straight through mufflers or incorrectly named 'resonators' whatever you want to call. How does it sound? Muffled.   Car runs richer now in low load. Is it restriction? Or lack of exhaust leaks. I also figured out a way to make the Analog Readout match the serial WB Readout. All of this requires a car to you know.. *start* to tune the maths, which was not ideal when I needed it to get to the exhaust shop and back. It started when cold. 30 mins after the car got home, it was time to get stuck into it. Unfortunately this thing has no identifying marks on it at all. I contacted Mal Wood and asked if he could send me a replacement and he asked me to remove it because they've changed starters with their kits a few times over the years. I asked other companies with LH LS starter conversions and they all use different starters unique to their kits. I did find CAE performance supply Mal Wood - But they are out of stock for this starter for the next 3 weeks. The tune is booked for Friday 30th. Here's hoping the local starter motor repair place (which interestingly has a 5 star review from Trent @ Chequered) can get this rebuilt/sorted out so I can get it on and put the car on the dyno. Here's hoping!
