  • Replies 55
i taught one of those newish r32 golfs a lesson roll on from about 70km/h to 110+++ km/h up a hill :) . Mines only making 200rwkw.
Yeah you would, they only run 14 second 1/4 miles. An R33 with 200rwkw will run low to mid 13s all day long.
Found this: http://www.ssmoparmuscle.com/speedcomp.htm
Though for some odd reason it has every other car except skylines? But a GTS25t should do 0-100km in 6sec and a 1/4 in 14 1/2sec.
According to it, a GTS25t is as fast as a impreza WRX 2005 but not some of the other ones.
If you can drive a Skyline well they might do a mid 14. Most completely standard will do low 15's, high 14's.
Yeah seems to be the launch that determines it, and needs some practice. Either i bog down or light the rears up. Only got it right maybe twice.
Feels like abusing the car though and asking for mechanical dramas, so i dont make a habit of practicing...
It's a US compiled list obviously - The Infiniti G35 on there = the V35 Skyline (US release).
Not a lot of earlier Skylines ever imported (bar a few GTRs) to the US as they are RHD.
On You tube there is a N/A with a simple exhaust mod and air intake that did a 14.6 1/4 mile... a stock turbo should be quicker than it.
Unfortunately one video on Youtube doesn't mean much. Most stock NA Skylines do 16+ second quarters and like I said most stock GTST's do high 14's low 15's. The driver in a manual Skyline plays a big role.
I have personally raced a fg xr6 twice and it flogged my r32 gtst one both occaisions in the
Wet I just couldn't get traction and in the dry it just ate me alive. But I had blow by.
And shitty chinese tyres. I had trouble pulling away from a liberty even.
Wat id like to know is on the aus300zx forum they say a r33 gtst is comparable to a n/a zed 32 ??? :D
Lol your kidding right?
An Aus spec NA 300ZX 5 speed when new was rated at high 15/low 16 second quarters.
Edited by PM-R33
Nah my mate is a really into zeds he owns three. I guess he's brain washed me too much lol.
Them aus300zx guys really are convinced I didn't think so either but then again I lost too
A n/a fg xr6 ute but that was in a clapped out rb20
I ran a 13.9 in my R33 4 door with 3" cat back and pod filter 9psi and shitty tyres 230hp , the launch plays a bit part in it if you can get it right with your power level then it takes off pretty quick... i managed to pull away from a R8 off the lights but i am making 188KW now though
"I have personally raced a fg xr6 twice and it flogged my r32 gtst one both occaisions in the
Wet I just couldn't get traction and in the dry it just ate me alive. But I had blow by. "
Ya, but a 2L gtst not as quick as a Gts25t.
"looking for boost"
Mint to pull away from an R8 with just exhaust mods and a little tune :D
    • A few things that seem a bit off here. - why is there 2 BOV’s?  - the turbo smart BOV on the compressor housing, is it turned up ALL the way? I have seen this become an issue on old man Pete’s car. It would push open and recirc, turbo speed would rise and the boost pressure would do weird things. - stock head? Does that include springs? - tried a different MAC valve? Is it plumbed correctly?
    • Photo of manifold showing gate location? I mean, it's 6Boost, so we probably shouldn't be worrying, but always wroth knowing what the layout is. Plumbed back to atmosphere? Or into the dump?
    • Yes correct. Also, I'd avoid applying it to soft paint (however I doubt you'll ever have to deal with it in practice). So any paint that hasn't fully hardened, could be a 1k paint that never fully hardened or it could be a 2k paint that was laid down thick and hasn't yet fully hardened.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
