as title says, brand new race seat. bride copy purchased from holfords in melbourne a few months ago for $700. has just been sitting in my bed room since, decided not to use it and need the $$$ so need it gone.
obviously as new condition.
PLEASE BUY I NEED THIS GONE!!!!
$465ONO
can u measure the base of the seat where ya ass goes mines pretty big and just wanna make sure it would fit..
hey mate, the seat base is 31cm at its smallest point.
Want cash....then i just racked up $420- ??? Cheers Mike o437123233
$420 is abit low, sorry. iv got interest at $450 so far.
Hi, Just wondering location? or will u post if required Cheers Paul
located in melb. i will post at buyers expense.
Wow, that is a pretty good copy...
From the pics it look pretty hard to tell the difference to genuine... Beside the sest backing... The strap holes are stamped amd even has the tag...
Makes me wonder why i payed $2.7k for my bride cuga
Yeah but the plastic ones weigh a tonne.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
