R33 2 door boot seal $15 pic
RB25 timing belt (brand new no packaging , was put on the motor and cranked 5 times but never ran) $40 pic
R33 2 door interior handles $15 pic
R33 2 door ecu kick panel $20 pic
R33 2 door rear view mirror $20 pic
R33 2 door map lights $20 pic
R33 2 door interior light $20 pic
R33 2 door series 2 console $50 pic pic
pick up from 5066 or postage at your expense
  • 3 weeks later...
  • 1 year later...
 Share
    • The 5 spd AWD boxes are all like-for like. They might not all be identical (covering >10 yrs of production means that many parts were updated as they went) but they are the same thing. You're not going to be swapping to auto.
    • Oh, oops, yeah, I'm getting the cams in the 2.5 replaced, so the above factory 2.0 cam specs don't mean 5hit, but, after alot of googling it seems the factory 2.5 cams don't like to rev So, yeah, there is that 🤣
    • Update - new drop of oil noticed. Leak seems to be continuing, but a slow/small one.
    • Hey y'all! So I am the owner of a shiny new '99 ENR34 25GT-Four, 5spd manual. Took it to the tire shop to get new shoes. They mismatched the front and rear axles (225/40s on rear, 225/45s on front), so AWD system went bonkers for the next day. Took it back in, they fixed it, but I noticed about 8-9 big drops of red fluid in my parking spot. Leaking has stopped, but it's clear that the transfer case may have been stressed/hurt by this debacle. I'm taking it in for inspection tomorrow. If things are FUBAR, I have a few questions. - ENR34 manual transmission transfer cases seem impossible to source. Can a GTR transfer case fit? Or if not the whole thing, just seals or components? GTR is 6spd, mine's 5spd, so I'm thinking no, but lmk. - Finding a few RB25DE NEO AWD auto transmissions for sale, for decently cheap. If my only option is to swap to auto, what else will I need besides an auto-specific gauge cluster, and associated wiring? - I imagine the R32/33 GTS4 transmissions/transfer cases are a no-go? They're not NEO engines, so unsure. - RB25DET/4WD setup from the Stagea, any parts that transfer over? I did search up for this on SAU and google, very little info covered.   This is my first post, so apologies for breaking any rules, please let me know, and thanks for the help.
    • Thanks. I agree, looking at those plugs in conjunction with good compression/leak down tests I'm not too certain its ring related anymore.  I have a Swagelok ball valve on the drain and tubed it lower down to the left side of car to easily dump it into a container. I do not drain back into the sump. I've never had to drain it though as there's never been any oil in it.
