can some1 please tell me what each hole on the intake side of the rb30 block is for and what i do and dont need?
i am not having a heater,aircon.
also i have a greddy copy plenum, what are the front 2holes for? also there is about 5holes and the back of the plenum?
A: - That goes to the heater core.
B: That is the rear knock sensor
C: This is left empty
D: This is the front Knock sensor
Blue Circle: This are for both of the water sensors. Beware - The single plug sensor is usually the wrong thread. You can either cross thread it in or re-tap it.
Green Circle: If you plan on removing the water to oil cooler, use this to put the oil temp sender in. If you keep it, there should be a bung in here.
Edited by The Mafia
