Nah it has been OC'd for close2 years now. Its a dual core e8400 running at just 3.3ghz on an aftermarket cooler, its barely even pushing the envelope. All temp settings are fine.
It only BSODs on me when watching you tube, or any movie file directly from the net. i think there is a clash somewhere between flash player 10.1, catlyst control centre and maybe even g19 gaming keyboard.
Ok can anyone help? this is the error i am getting......
Product
Windows
Problem
Video hardware error
Date
26/07/2010 12:40 PM
Status
Not Reported
Description
A problem with your video hardware caused Windows to stop working correctly.
Problem signature
Problem Event Name: LiveKernelEvent
OS Version: 6.0.6002.2.3.0.768.3
Locale ID: 3081
Files that help describe the problem
WD-20100726-1238.dmp
sysdata.xml
Version.txt
Extra information about the problem
BCCode: 117
BCP1: 873ED510
BCP2: 8C9265E6
BCP3: 00000000
BCP4: 00000000
OS Version: 6_0_6002
Service Pack: 3_0
Product: 768_1
Sounds like a video card fault - take it out and reseat it.
Could also be the PCI-e slot failing as well, so try another PCI-e slot (if you have more than one)
Seriously guys, we get better, faster tech support on SAU than we do when we have to call up Optus for example ;)
check for latest drivers directly on the nvidia or ati etc website, vendor websites are often not upto date. If you already have the latest driver id suggest getting drivers from a couple revisions ago. Another alternative is if its only happening when on the net try using a different browser until a new version of flash is out. Due to that vulnerability recently I assume the release of 10.1 was rushed
He's already tried the software route - im pointing fingers @ hardware issues now we've been given some more detailed info.
lol f**k a call centre off - here you are getting people who've done this for years in practical - not just on paper like most guess-centres.
:P
No Sh*t, i must say your assistance from all of you guys is unbelievable, awesome work you loT! saves me a call to India thats for sure :-)
Ok tomorrow morning will pull out the gfx card, try different pci slot, uninstall drivers on gfx and try again.
Edited by 25GTT
Do it this way.
- Uninstall
- Reboot/Load Windows
- Shutdown once computer is idle
- Remove GPU and sit on table
- Turn on/Load Windows
- Check Hardware (type: "Device Manager" into Win7 Search, hit enter) and ensure there is no device listed under "Display Adaptors". If there is something still listed - disable it.
- Install GPU into another PCI-e slot
- Once PC is idle, then load driver
See how you go then and let us know..
It's a specific order i know, but you need to follow it this way to get Windows to recognise correctly a device has been fully removed and is sitting in a new slot at times
Sometimes you don't have to do all the B/S above, but I've seen my own PC crack the shits if i didn't do this on one occasion.
After that - repeat the above with another GPU if you have one, trying ALL slots on the mobo and then see.
give it a clean and underclock first, sometimes can be a f**ked fan on the video card (easiest way to eliminate is to try a different one).
For example, I've had my 4830 overclocked for a year, but started to get artifacing and freezing in games. Underclocking the VRAM clock 20mhz fixed this.
Did you make sure the PCIe clock was still at 100 when it was OC'd? Might have been fine in XP/Vista but issues have shown up in 7.
I love my Classified board and being able to disable each PCIe slot individually.
Also what version of the ATi drivers and CCC were you running?
Nismoid - Awesome mate, was going to do it this morning but am now at work, am going to do it now friday night step by step as you mention. Might just check my gigabyte board specs as well to see if i have another PCI slot.
Div - ok i am sure it was catalyst 10.6, i only re updated it about 2 weeks ago so its the newest version, as the older version was doing the exact same thing. When i OC'd i remember you guys saying to make sure the pcie clock stays at 100 so i set it at that but will double check everything. OK just noticed there is now a 10.7 so donwloading now
Boz - its not overheating at all, it only restarts when a youtube (flv file i think they are) is played
its just weird, i have had the 5870 now for about 3 - 4 months, didnt have a prob until the new flash player was installed.
THanks again guys for your help, will let you know how i go with all of this on Friday night
download driver sweeper and remove all drivers and download up to date versions of them :) fairly common problem, after updating my drivers my computer wouldnt boot.. so downloaded driver sweeper ran in safe mode, removed all drivers and booted up in normal mode again.. worked fine.. installed drivers again.. worked fine..
UPDATE
Ok guys an update on this, so i spent about an hour and a half tonight mucking around removing and installing removing drivers again.... GOOD NEWS, well kinda.....
removing all of my 5870 drivers off the system i can now view you tube etc i then reinstalled adobe flash player 10.1 and i could still view your tube. INSTALLED THE LATEST VERSION 10.7 OF ATI DRIVERS AND IT CRASHED!!
So i can now bring it down to the ati drivers clashing somewhere in the system...
Where to from here? should i keep on uinstalling the ati driver until i find one old enough (maybe 10.2?) that doesnt clash??
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
