Thanks to the master of Cobb Tuning and GTR engine management John Banks the R35 operating system has been re-written yet again over the past few weeks :)
After rewriting the entire boost control code to make the GTR management work properly at higher than stock boost (plus a host of other stuff) it was time to program and 'crack' the launch control in the TCM. Now this has been achieved there are some other cool things on offer that put the factory GTR computer (when tuned with an Accessport) beyond the realm of anything the aftermarket have so far dreamed of for these cars.
The first innovation is using the factory big single boost gauge as a 'Knock Light'. Remember the flashing check engine light on the Power FC? The Cobb Accessport tuned GTR computer can now do this, but even better. Check the demo -
When you see the boost gauge flash its an indication that the GTR knock sensors have been alerted to detonation. The computer then rectifies the ignition timing automatically, but still lets you know its happened.
Then there is the intelligent map switching. Your tuner can write 9 different engine maps into the GTR computer with different boost levels, fuel, timing etc. and you can switch between them on the fly using the cruise control buttons on the steering wheel. Look at it in action here -
The possibilities are absolutely endless and the integration is astounding :)
Exciting times are ours :blink:
Cant wait to test this over the next few weeks! :D
It will be interesting to see what the new HKS V-Pro http://www.skylinesaustralia.com/forums/Hk...ar-t330492.html has to offer in comparison. Is this available in Australia yet Martin?
Cheers
Marty
I am not sure about the availability of the F-Con.
What I do know is that nothing compares with programming the native code in the factory computer.
Now the interface between the MFD and the PCM has been cracked I think the public will be able to look forward to some spectacular innovation.
That is just amazing what they're managing to do reverse engineering the OS like that. I can see custom MFD screens on the horizon in the foreseeable future! Run everything including map switching from a custom GUI all controlled via the touch screen! How neat would that be....
And agree fully on using the factory ECU over aftermarket. Why stuff around with all the factory settings that do not need to be changed once you can do everything that you need with the OEM ECU.
I am pushing for that custom GUI but apparently its fairly difficult.......time will tell
9 independent maps at the flick of a switch (Cruise Control buttons) is pretty spectacular for the time being! :)
Real Time tuning is just around the corner as well, being tested currently, all using the on-board RAM in the factory GTR PCM
  • 2 months later...
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
