Assuming these are similar to rb26 being solid lifter... however as it also has vct should i assume that it has different length springs on the inlet compared to the exhaust like the r33 rb25 heads?
anyone done cams before on a non turbo r34 neo head before?
https://www.sau.com.au/forums/topic/330577-cams-for-rb25de-neo-head/
Aren't the N/A NEO heads super nasty in terms of flow?
I remember seeing pics of a NEO-N/A & a NEO-T and if my memory is correct there was a fairly big difference which would make a non neo a bit nasty ;)
yeah.. but its on there already. might just leave it stock for now.. and change to one of my spare 26 heads later down the track
big difference intake side.. ALOT of meat could be taken out easily. but.. its all assembled and ready to be started.. but was looking at dropping some cams in just for time being.
I remember seeing pics of a NEO-N/A & a NEO-T and if my memory is correct there was a fairly big difference which would make a non neo a bit nasty :down:
and wow.. just round the standard cam specs on the non turbo neo head in comparison to the others
R32 Skyline RB25DE Camshaft duration 240°in, 232°ex lift: 7.8mm in, 7.3mm ex
R33 Skyline RB25DE Camshaft duration 240°in, 240°ex lift: 7.8mm in, 7.8mm ex
R33 Skyline RB25DET Camshaft duration 240°in, 240°ex lift: 7.8mm in, 7.8mm ex
R34 Skyline RB25DE Neo Camshaft duration 236°in, 232°ex lift: 8.4mm in, 6.9mm ex
R34 Skyline RB25DET Neo Camshaft duration 236°in, 232°ex lift: 8.4mm in, 8.7mm ex
Stock neo turbo cams are ok, but f**king shit on the exhaust side of non turbo :S ! definately goin to run it how it is and throw an rb26 head on it later down the track
  • 2 years later...
Thread Necro but I am in exactly the same position now.
I only really need to change the exhaust camshaft (so no worries about CVT), is there any problem with dropping a 26 exhaust camshaft in? I presume I just need to make sure the CAS has the same spline (ie use the 26 CAS instead of 25).
I can't find any information about the springs or valves being different between rb25de and rb25det neos, although the intake runners are definitely narrower on the DE.
Edited by Sarumatix
  • 4 months later...
thread revival, does any one have any info ^ mentioned above
Edited by dori33
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
