love the 20bTT cosmo
but Im too tall to even get into the drivers seat behind the steering wheel
heavy car as well, not in the same performance league as a skyline in my humble opinion
try a stagea on for size.
  • Replies 176
man you can't read. mabee i shud typ like this n wotever fckn dic and then u can go fck ur dads arsehole. In reality my car's stock redline is 8,000. so no, unlike you I refrain from having a man sodomize my esophagus.
can u speaka da engrish, so sorry thats right ur not
what a grump thready.
fwiw i used to run my 33 gtst at 5000rpm in 5th for 30min on the way to and from work each day for almost a year. I hope someone can work out how fast i was going.
also, out of interest, if a 33 gtr leaves the mine at 6000rpm for 10-12 minutes in 5th and a 33 gtst leaves town in the opposite direction at 5000rpm for 30 minutes, where will they cross paths? or when will the floor blow out?
Depends on where they use the nos, right?
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
