Hey guys inspired by the tech support in other threads I thought I would post my PC issue here.
Currently my computer is crashing randomly when i'm playing random games, the screen will go black, the monitor stand by light will come on and the fans will run at 100%.
First off the relevant specs
Athlon X2 4800+
Nvidia 9600GT
4GB of RAM
Windows XP Pro
Brand new 750W PSU
I at first assumed it was overheating but on closer inspection the temperatures are all well within safe tolerances.
CPU 65-70 when playing games
GPU 55-60 has an aftermarket fan set up
Drivers are all up to date. The stange thing is it happend just before when I was playing Star Trek: BC which came out in like 2003 yet still crashed.
I am a bit of noob when it comes to PSU voltages, in all my years of working on computers I have only twice encountered any PSU problems. My PSU +12V is reading as 12.35-12.42 and I think that may be an issue, although some say as long as its within 5% of what its supposed to be all is well.
Ayways any help from the SAU tech support team would be greatly appreciated.
https://www.sau.com.au/forums/topic/330610-black-screen-fans-running-at-100/
Well you say the 750W PSU is new - did the problem occur before or after its installation?
Do you have another PSU around? 750W PSU for a 9600GT is the most ridiculous overkilll, you could get away with a 450w PSU.
Fans going to 100% is just because there is a lockup, it's not the actual problem, just a result of it.
Yeah I know its overkill, the old one was dying recently and so I got the 750W based on the new CPU/Mobo/GPU/RAM set up I will be getting shortly.
Yeah I could try the old PSU it still works just not very well, the problem did occur before I installed the new power supply.
Is 12.42V on the 12V an issue? unfourtunetly I dont have much experience when it comes to that sort of thing.
Thanks for the help so far keep it coming.
PS. forgot to add that when I turn on the computer the CPU fan quite loud until about 10 seconds into the Windows boot screen, that has been occuring for a while now but because the computer is on more or less 24-7 its only been a mild annoyance.
Edited by FrangaR33
The 12v should be fine. As has been said the fans are pretty much unrelated though you could try running MSI Afterburner or similar and manually setting the fan speeds and see if it still changes. If it still does it is probably crashing, attempting to reset and sitting at pre-POST where fans can be at 100% by default.
Edited by DivHunter
I will adjust the fan speeds with Riva Tuner and see how I go, what could be causing the crash and make it sit at pre-POST?
If it was me I would be using driver sweeper, removing everything and going online and downloading everything up to date, IMO looks like video card is just crashing and causing system to just lock up, maybe if you have already tried new drivers maybe try a older version of them.
checked connections to monitor and computer? (i work in a helpdesk and this happens more often than you'd think!)
Also, what brand of PSU is it? I had a similar thing happen when trying to cheap out on a computer I was building and using an Ebay PSU, piece of shit also ended up frying the cheapass mobo I had gotten LOL. lesson learnt there!
Yeah I checked the connections, i've done a bit of help desking too and I know how often it can be something stupid.
Its Aywun Megapower 750W PSU, so on the cheap side but definetly a lot better than a elcheapo ebay job.
er who?
After a quick search the general concensus is they are rubbish, possibly worse than Shaw and most likely lying about their 80+ certs. They can achieve decent efficiency it seems but that's only one part of PSU quality.
Edited by DivHunter
er who?
Yeah I know there not great, but they will do for the intended purpose and it has a 3 year warranty. My last ebay PSU lasted 3 years before dying so I was pretty pleased with that.
As far as my problem goes i've reinstalled the latest drivers and used Riva Tuner to up the fan speed no problems yet. Although the fan still spools up hardcore when I restart or start up the computer.
do you have another PSU availible to eliminate the possibility then?
It was still ocurring with my last PSU which I still have, also I dont have another PSU powerful enough I have a couple of old 300W units kicking around but nothing powerful enough for this computer.
If it's stopped with a higher fan speed it might be memory or VRMs overheating.
The 100% at startup is a card BIOS setting and is pretty normal.
Okay thanks the help guys its much appreciated :P . Hopefully when I get the new set up in the next couple of weeks this cease to be a problem anyway.
Edited by FrangaR33
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
