Hey guys inspired by the tech support in other threads I thought I would post my PC issue here.
Currently my computer is crashing randomly when i'm playing random games, the screen will go black, the monitor stand by light will come on and the fans will run at 100%.
First off the relevant specs
Athlon X2 4800+
Nvidia 9600GT
4GB of RAM
Windows XP Pro
Brand new 750W PSU
I at first assumed it was overheating but on closer inspection the temperatures are all well within safe tolerances.
CPU 65-70 when playing games
GPU 55-60 has an aftermarket fan set up
Drivers are all up to date. The stange thing is it happend just before when I was playing Star Trek: BC which came out in like 2003 yet still crashed.
I am a bit of noob when it comes to PSU voltages, in all my years of working on computers I have only twice encountered any PSU problems. My PSU +12V is reading as 12.35-12.42 and I think that may be an issue, although some say as long as its within 5% of what its supposed to be all is well.
Ayways any help from the SAU tech support team would be greatly appreciated.
https://www.sau.com.au/forums/topic/330610-black-screen-fans-running-at-100/
Well you say the 750W PSU is new - did the problem occur before or after its installation?
Do you have another PSU around? 750W PSU for a 9600GT is the most ridiculous overkilll, you could get away with a 450w PSU.
Fans going to 100% is just because there is a lockup, it's not the actual problem, just a result of it.
Yeah I know its overkill, the old one was dying recently and so I got the 750W based on the new CPU/Mobo/GPU/RAM set up I will be getting shortly.
Yeah I could try the old PSU it still works just not very well, the problem did occur before I installed the new power supply.
Is 12.42V on the 12V an issue? unfourtunetly I dont have much experience when it comes to that sort of thing.
Thanks for the help so far keep it coming.
PS. forgot to add that when I turn on the computer the CPU fan quite loud until about 10 seconds into the Windows boot screen, that has been occuring for a while now but because the computer is on more or less 24-7 its only been a mild annoyance.
Edited by FrangaR33
The 12v should be fine. As has been said the fans are pretty much unrelated though you could try running MSI Afterburner or similar and manually setting the fan speeds and see if it still changes. If it still does it is probably crashing, attempting to reset and sitting at pre-POST where fans can be at 100% by default.
Edited by DivHunter
I will adjust the fan speeds with Riva Tuner and see how I go, what could be causing the crash and make it sit at pre-POST?
If it was me I would be using driver sweeper, removing everything and going online and downloading everything up to date, IMO looks like video card is just crashing and causing system to just lock up, maybe if you have already tried new drivers maybe try a older version of them.
checked connections to monitor and computer? (i work in a helpdesk and this happens more often than you'd think!)
Also, what brand of PSU is it? I had a similar thing happen when trying to cheap out on a computer I was building and using an Ebay PSU, piece of shit also ended up frying the cheapass mobo I had gotten LOL. lesson learnt there!
Yeah I checked the connections, i've done a bit of help desking too and I know how often it can be something stupid.
Its Aywun Megapower 750W PSU, so on the cheap side but definetly a lot better than a elcheapo ebay job.
er who?
After a quick search the general concensus is they are rubbish, possibly worse than Shaw and most likely lying about their 80+ certs. They can achieve decent efficiency it seems but that's only one part of PSU quality.
Edited by DivHunter
er who?
Yeah I know there not great, but they will do for the intended purpose and it has a 3 year warranty. My last ebay PSU lasted 3 years before dying so I was pretty pleased with that.
As far as my problem goes i've reinstalled the latest drivers and used Riva Tuner to up the fan speed no problems yet. Although the fan still spools up hardcore when I restart or start up the computer.
do you have another PSU availible to eliminate the possibility then?
It was still ocurring with my last PSU which I still have, also I dont have another PSU powerful enough I have a couple of old 300W units kicking around but nothing powerful enough for this computer.
If it's stopped with a higher fan speed it might be memory or VRMs overheating.
The 100% at startup is a card BIOS setting and is pretty normal.
Okay thanks the help guys its much appreciated :P . Hopefully when I get the new set up in the next couple of weeks this cease to be a problem anyway.
Edited by FrangaR33
    • Been so long since I have been here,seeing SDU is dead. I had that problem on my gtr in 2006 but luckily there was no engine damage,it was inspected by Hytech Engines,race bearings and extended crank collar put in and that was about it. Hopefully yours is sorted now.
    • Would it not be cheaper to just spray nitrous?
    • I've got cash, it's the NA LOLS I'm after now Plus, I've had a few boosted cars, and it is soooo easy to turn a reliable car into a unreliable drivetrain eating money pit monster by just paging up and chasing more My power goal for the NC is to try for a reliable naturally aspirated 150kw or 200hp atw (I'm old, and the old naturally aspirated cherry of 100hp per litre is a goal that I would like to hit), no more is really needed for what I use the car for,  so a additional 5kw is what I'm chasing now,  that 5kw is about $3k away, I think....
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....🤣) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
