You feel it because you are bouncing around adn on the long sweeper you are falling out of the seat....anyway. Will post up pics to show why they are shit when it comes out again. Need to go back and do my EVO III Brisasaurus seat rail. (ie for prodigious units)
And a few pics from Sunday, my bus next to a friends new EVO. Kind of mutant cousins, both 2L, silver with black wheels :)
Thanks to Martin for the pics from the weekend...the brakes work well :) ... lap after lap :)
Lap 1
Lap 2
Lap 3
Lap 4
The PFC06 pads were really nice when hot. They were a bit grabby when cold which meant I was locking them up pretty often. But when up to temp they were a lot easier to modulate. Seems for the car weight, tyre grip and rotor (cooling) size I need to run a pad which comes up to temp a lot quicker. Also need to get the car's susp setup properly, I have big front ARC swaybar which seems to be unloading the inside wheel when i turn in trailing the brake a little. By the time I start to turn in I am only carrying a little bit of brake but is enough to lock the inside wheel when the big bar ties the sides of the car together and unloads the inside tyre :(
SO need to get the car's ride heights set, rose joints on the front bar set correctly and maybe backed off a little along with a good wheel alignment. has not had one since start of 2009 :)
...and some not so incrimating pics
A shudder developed on the last of the few laps i ran at Sandown last weekend. Show up during the little street driving i did and during the firsf session at winton. Took the wheels off and checked everything was tight and nothing had loosened with the first lot of heat cycles. Nothing unusual but was able to nip up a ted. Checked pads and they were badly glazed. Cleaned up the pads and were brilliant from then on.
So maybe i under did the bedding. Or the rainearly on in the running in of pads/rotors. But what felt like warped rotors was just pad glazing.
That tyre end up feeling like you were driving on a 50c piece after the lockups?
I flatspotted mine at the top of 4th, only just touched the brake and jumped straight off when it locked but the damage was already done. Was like driving on a pogo stick around corners from then on :(
Because my lock ups were typically at the endof the braking zone my road speed was pretty low. You normally only badly flat spot tyres when you have some speed on board. i did actually pick up a flat spot the time i grabbed a brake early in the braking area. It probably was the reason it was locking so often afterwards, even when at lower speeds
Hey Roy,
Love the build up, very inspiring, most brisbane and GC based RB20s get pulled out for 25s or 30s, ive always wanted to keep mine, nothing like the work gone int your tho.
Some thougths on your brakes locking up, id say the front needs corner weighting, did it lock the right front on other corners, when it was inside wheel? It maybe that your ride heights are causing corner weights to be far to light on the passenger side causing the lock ups.
How do you find the power, even after all of your experiments, it looks wuite drivable, power band of 4500 to 8000 i doubt you would drop off boost, so shoud be ok. Does it come on too strong for corner exit traction on faster corners in 3rd and 4th or only in 2nd gear lower speed corners?
Keep up the good work, love it. Just wish I had the money to do what I dream of doing to mine.
I want 250rwkw so a healthy 400 flwhp and then suspension and handling more than more power. My goal is for a set of MCA coilovers, I know his son so support should be good, and go from there.
I spun the Radical out of turn 3 at EC on slicks with a damp track and flat spotted all 4 tyres. I wouldn't have thought it would have done it so easily but with a bit of speed on board looks like its very easy to do.
Car look fantastic mate :thumbsup:
car looks awesome mate. and yeah brissasaurus racing evo 1 seat rail is still firmly attached to my seat mate. :) fark it's heavy though so if you do go ahead with evo III make me one! I'll actually pay for it this time... :)
ps I still have your koyo radiator here mate. want me to send it? or sell it? etc.
come up and stay at my place for a bit. i'm bored, have spare room and a keg of beer.
Just got approved 8 weeks of paid/unpaid leave. First few weeks will be just winding down, then OS then back relaxing...ready for more headfark projects uopn my return. So early July shoudl be some fun at EC/Wakefield and running amuk on Chateau le Count! :)
Thanks rotort...yeh, i love the lil 20. Yes, its still very drivable. I am a bit disappointed its not more of a wrestle to punt...but truth is its still quicker then me so am still chasing the speed the car has. Re setup, the car had a wheel alignment in Jan 2009, since then it has been in pieces, stored and no idea of ride heights etc. I suspect you are right as it only locks the front left when there is a bit of lock on so could be tied up with the too big a front swaybar with rose joints, ride height etc etc.
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
