I'm using the stock mani but it has a very good welding job done on it and has a collector with a 38ml gate and screamer on it. I have a bleed valve ,z32 afm with big pod,oil catch tank,fmic,full 3inch exhaust, gtr injectors and reststor pack,new yellow jacket coil packs, power FC with controller plus have just scored a aftermarket clutch and lightened flywheel and am thinking of cams and if needed a oil cooler..
Edited by Co-stan-za
I went backwards with Apexi 260/8.8mm cams so removed them after hours on the dyno and some disappointing results from the test drive. They did sound tough though :) So I would hold off on cams and go with the oil cooler.
The TD06-20G and RB20 will never have the response of some of the other combos, but it will be a reliable grunter able to run 12.2-12.8sec qtr miles so still a respectably quick car. I would prefer it over the other options you have but the real test should be for you to go for a drive or get a steer of a car with a similar setup to see if that's the direction you really want to run.
1329105757[/url]' post='6232234']
I have been in a sr with 3071 and did like but that thing needed around 20 psi to start getting on song and I have owned a td05-20g so as i liked the feel of that I decided to go the td06 l2 20g 8cm and went and picked it up yesterday. Will be going in next week,only thing is I'm trying to get a t3 to 3 bolt trust style flange adaptor for my mani as I dont have a grand for greddy or good aftermarket mani..will post up dyno chart next week.
1329448924[/url]' post='6239209']
Let us know how u go mate as I've always wondered the dif between the 05 and 06 7cm vs the 8 cm 06.Cheers
nice!!!
did you hear?
you've been approved.
For what?
As for living the dream? I wish! I hate having to travel to earn a dollar in my industry. In the last 10 years I have been OS for 4-5 years of it in countries most people would be happy to holiday in for 10days :( Living the dream would be a job, a house and my cars. Not a career, bad health and impulsive automotive buys to make up for everything being pretty shitty :)
Really depends on funds. I really need to stop buying mid price shit boxes and stop the cash burn on cars. At the moment I am thinking E30 EVO III M3, and a Viper of C4 ZR1. Love to get a ZO6 but need to get something I will flog off and think a Viper would be the way to go. Will keep the M3, and maybe the ZR1....but yeh. Will have to consider a cheapish car I can keep or a car I can flog for a small profit to help pay for a mancave. (which is the main reason for going OS with work...try and get some cash together because of stupi real estate prices)
i like the c4, which z06 where you looking at c5 or c6?
c5 zo6 seem to go for about the same as c4 zr1's, ($20.000 to $30.000) so depends on which one you like. :)
vipers don't seem to be easy to sell in aus, but you can always drive it till you sell it.
have you seen these?
http://www.shelbyautos.com/vehicles.asp
Well, my motto is money is only important if you don't die tomorrow! :whistling:
So The E30 is a pretty much sure thing. If I can get a Sagaris as RHD car into the US and it is counted as a private import with regards to bringing it back to Aus then that may be the go. But odds are it will be an E30 to keep and perhaps something else as something to try and import and turn a profit...so dont really care what it is as long as its fun to drive/own for 12 months in the US and doesnt cost a fortune in parts when I break it at whatever tracks I get to...of course this is all assuming i can keep my Russian bride employed and bringing in the coin :thumbsup:
    • Pic of Nos, turbo kit and sequential not loading. 404 not found
    • im sure mine stays in gear and wont shift unless i shift it? and for sure it wont go back to Auto mode if its put in manual mode? if i use paddles but its still in D then of course it goes back to auto mode. but yer if its in -+ and i use paddles it will not auto change gears what so ever and i have tried this. it will gear down if at a stop though which is kinda nice but goes back to 1st gear not D. i think it used to be like this with imports aswell i dunno if its really like it anymore like when i got my R33 it had alot of JDM options which local cars didnt have. Now local cars have kinda caught up even the lower models. but yer transfer rates and other things makes it almost on par.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
