There were plenty of older vipers around when i was living in florida... anywhere from 25k and up.
They are FFFFF UUUU NNNNN !!!! to drive! fairly easy to get parts for too.
... You HAVE to hit up MOROSO motorsport park if your down south.
Hanging out of your turbo comparo.. I'll be ordering my billet goodness as soon as you post up.
Cheers
Justin
Yeh, the turbo comparo is pretty stupid now as its dead money that will just sit in a shed for two years. But i am curious to see how the lil 20 goes with 1.8-2.0bar with the 73HTA and E85. God knows the EVOs keep making power at high pressure ratios with these turbos so :merli:
  • 3 weeks later...
Well, when it come to the crunch I think I am truly sick of travelling with work so unless its Belgium, Switzerland or Ireland I am not going to bother.
So car has been stranded in Sydney, should be getting it back in the next week or so. In the meantime I have kept myself sane without her by planning this trip to Germany-Belgium with a few friends.
And for two days this was my track car at Spa :)
  • 4 weeks later...
Yeh std 210,000km gearbox. Secret is to use a sprung centre single plate puck clutch and CASTROL SYNTRANS 75W-85.
Cheers for that! Been worrying my gearbox would s**** itself at 200+rwkw, good to see at least one re-assuring result.
    • Pic of Nos, turbo kit and sequential not loading. 404 not found
    • im sure mine stays in gear and wont shift unless i shift it? and for sure it wont go back to Auto mode if its put in manual mode? if i use paddles but its still in D then of course it goes back to auto mode. but yer if its in -+ and i use paddles it will not auto change gears what so ever and i have tried this. it will gear down if at a stop though which is kinda nice but goes back to 1st gear not D. i think it used to be like this with imports aswell i dunno if its really like it anymore like when i got my R33 it had alot of JDM options which local cars didnt have. Now local cars have kinda caught up even the lower models. but yer transfer rates and other things makes it almost on par.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
