No noise day = PIARC day?
Yep! :)
The thing was maxxing out its GTR injectors with a belly full of corn syrup so not a lot of time was spent trying to get a result, just a few dyno pulls to see how it behaved. So its hardly an exhaustive test and tune with E85, its just a little disappointing that other cars fill up with E85, load more fuel and ignition and they readily show signs of making more power vs my car that seems a little more stubborn.
Fark Garret fluff..i have a an army of Mitsubushi turbos that will go on before I soften up and go roller girl bearing
Just need to sell a few more parts so that I can play with the R32 whilst rebuilding the Sierra :)
We knew it was going to happen, just wanted to try the corn juice to see if the engine liked it and whether it helped its tendency to ping. I think if nothing else this test has told me there is nothing magic about E85 and if you are out of compressor flow then you are out of compressor flow and E85 will only give you a few more killerwasps :(
I have not bothered as the 20G with a 10cm housing was too big for an RB20. So I am betting a 25G would be rather ordinary on a 20. Would probably make a good number, but would make less than 200rwkws at 5,200rpm :( If i had a freshly built RB20 that I knew was well balanced and had a good oiling system it would be probably a decent enough thing to spin up between 5,500-9,000rpm.
If I can sell some of my fluff laying around I could quite possible give the T67-25G a nudge. The crime will be is if I run it with E85 and the 10cm housing I will instantly losing $300-500 as it is brand new. Think I will have enough trouble selling them with the Kando things running around but not fussed. Some of the gear I dont really want to sell, just need to move enough to clear up some funds for further work on the R32 and Cossie rebuild
The 25G wheel is 15% bigger than the 20G wheel, so with the little 69.7 mm stroke of the RB20 and 8.5:1 compression, like i posted above I dont see the RB20 doing a bang up job of getting the most out of the T67.
That's why I grabbed the 73HTA wheel, it is only 7% bigger but is lighter so stands a chance of spooling as well, if not better than the 20G wheel.
But for now I have decided I am going to shelve the plans for the 73 HTA and see if the lil std motor can handle the corn syrup and the power it makes with the 20G for a few track days.
I figure 306rwkws is a decent enough step from the power I was previously running and now getting into the area where I am less confident about how well a std engine with at least 60,000kms (i have put those 60,000kms on the wrecker engine) will do with that sort of grunt, boost and revs
I'd say its the turbo. they are only a 450hp turbo arn't they?
The way the boost trails off means the engine is taking more air than the turbo can produce. If you have a smart enough boost controller you can get around it. But the turbo will hate life
Edited by sav man
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
