Phil, No idea when first session is. I am guessing kicks off 9:30ish and may have had one session by lunch.
Still got std diff ratio and std 210,000km old gearbox. There is some money being placed on box not lasting the weekend. I have no worries. Old RB20 boxes are tough :rolleyes:
So the cams gave a sniff that there was more to come. The new turbo has given a sniff that the setup is moving in the right direction.
Seems my R32 is more 58 Plymouth Fury and she doesn't like the extra cubes in her and is playing silly buggers somewhere in the setup. Think dirving around with a head gasket issue with condensation in the exhaust on biref trips etc may have collapse the muffler in the 11 yr old HKS exhaust. I hope its something as simple as that because there seems to be an odd restriction somewhere that means we make ok power but not what we shoudl be :(
Meanwhile, I need this spend to stop so I can count my cash and go buy my Sierra an 80s dance partner at the end of the month
http://www.importmonster.com.au/view?url=http://page21.auctions.yahoo.co.jp/jp/auction/j229858495&thumb=http://auctions.c.yimg.jp/f13batchimg.auctions.yahoo.co.jp/users/1/4/3/5/gensen_fujicarsjapan-thumb-1364822988738188.jpg&title=S62%20GTS%20RBBS17%20AW%20com
i saw this when i was hunting for a caterham on yahoo japan. ;)
Dont know exactly. Tuner and I agreed not to worry about a number. Just run it up, leave plenty in reaserve re fuelling and lets get a good benchmark and some kms on it. Still needs work on fuel setup and cooler piping etc etc. Is somewhere around 300-320. Depends on whether we go for 16psi or 18psi. Dont care just want to it safe to get some track miles under my belt
That's the spirit! Track miles is what it's about!
Well engine seems pretty healthy. Only got two laps before hitting problems but the one lap where I came on to the straight with traffic I was still 24km/h up on my previous best stratightline speed. SO thing has a load more mumbo then the old 98 tune on the 20G.
The only pic from the day, idle in the pits :)
I think its the front right king pin bearing on the hub to upright. Tyre now rubs on upright :(
Funny you should say that, my 34 has just done the exact same thing :(
Engine bay looks great too Roy :thumbsup:
Me too! Kingpin bearing is flogged out. but i reckon mine has something to do with 295 semi slicks and lots of track days haha. They are sooo expensive to replace! Something like $800 each from Nissan Japan. They're not servicable. Gotta buy the whole upright!
Yep i just went second hand and will see how it goes :unsure:
The bearings in the upright (that hold the kingpin) are a serviceable item. I takes some pasence to get them out without damaging the upright, but it can be done pretty easy. I recently changed mine
Edited by sav man
Went through the same deal with Jimmy33t also, he found this number BRG A-KINGPIN 40030-33P12
Its the main one, any bearing shop can match the smaller one. Be careful of the lower seal, expensive item through nissan australia
...sounds like we need a tutorial developed for how to do the kingpin replacement - I'm concerned about mine now :wacko:
How's the gearbox going Roy? My 20 box lasted for 22 years (with 6 years of that mated to a RB25 making around 240rwkw) and it wasn't until I went for mega torque with my GT-RS that it started making bad noises.
Not that hard to change really, found a tapered roller bearing replacement also which has preload when fitted and no shimming required
Here is my graph. Pretty lazy at the moment as no boost or ignition really thrown at it at the moment. Not until we get some kms on the new engine and get the gearbox and rear end/diff fixed.
At the moment there is no EBC, just s soft gate spring with a bleed.
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
    • Yeah, my offer was more to show exactly how rough and ready the rig can be and still be useful. Youtube vids will definitely show cleaner setups. Same concept though.
    • I would guess the seal has gone down at the speedo drive and gearbox oil has crept up the drive cable sheath and fouled the speedo head.
