All gone I unfortunately. All i have is a TD05-18G laying around
What were the Kinugawa like?
I can get a T67-25G with trust housing from them.
The brand whore in me says stay Trust.
But it's over double the price.
Not keen on getting the L2 modified.
Will either swap for a Trust T67 or keep I for a rainy day.
My Kando is new so cant really comment. Having ran a TD06-20G 8cm and T67-10cm in my RB25 i petsonally suggest you get a 10cm housing fot your L2. On E85 eill make a fat 310rwkws...made for a way faster street car then the T67. The one PI day i did with the T67 it was a good thing good  mud and strong top...but on the street the 20G was waaaaay punchier and pulled way harder in tbe mid to top...just lacked that extra 50rwks after 6,500rpm that the T67 happily saw up top to 8,000rpm
That's my concern. Too small for the 2.5L.
The L2 with 8cm rear should make 315 according to the trust book.
Compressor side is the issue. Cropped wheel and all.
45 degree curve and out of puff very early I believe is what to expect.
Perhaps just go with it and see what it does on the dyno?
  • 4 weeks later...
  • 1 month later...
  • 6 months later...
On 11/13/2018 at 9:28 AM, Roy said:
So...this will keep me honest...
Thanks always to Racepace for being able to make a bunch of mismatched parts cobbled together work so well
That’s some nice streetable horses!
So 2 days at Bathurst didnt go to plan. Slapped enough stuff together to do only 1 lap. Fuel filler tank kept spewing fuel meaning meatball flags. Then had a few other small similar things go astray...and ultimately fixed a few things on the fly that called into question  othet things that need a dyno run to work through so only did a lap at gate pressure
Running twin GT2860-5s
T
So looking back a week later now I feel frustrated. The first and only lap was a rather leisurely lap and not bad at 2:42 all things considered.
Wish I could have gotten another 3-5 laps as I think I would have gotten it down into the low 30s or high 20s rather quickly. After that its going to take a load of laps to get anywhere near the limit....but not even worried about that. Its definitely a place where you need to treat it like a tarmac rally and appreciate that a pinched brake may mean a horrible table top ride back to the pits :(
Anyway...over the next few weekends will need to fix the stoooopid filler neck. Fuel tanks check/roll over valve and stupid radiator shroud that decided to crack and meet the viscous fan. Stooopid old cars and meatball flags! ?
  • Like 2
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
