  • 3 weeks later...
Just finished reading the whole 20 pages of thread..:)
Top yarn, so pretty much you would recommend from a stock 20' to go for
*power fc
*trust td06 20g 8cm
*greedy mani and wastegate
*stick with oem plenum and cams,few gains from gears?
Just trying to get an idea of what I need to get to around the 240-250kw region,
And am assuming I could probably have a more responsive, snappier setup by dropping down to a 2530? Wouldn't bother dropping the overall power output if it wasn't much more responsive
yep spot on mate. to that list you need to add some injectors, fuel pump, Z32 AFM, good exhaust, front mount intercooler and a decent clutch. and yes it'll be more responsive with a 2530 but no where near the top end hit of the old TD06. probably a faster road car though but less fun on track.
Yep yep do see where your coming from re the turbos. I understand the other things u said ie z32 afm fuel pump, good fmic, just wasnt sure on the main power getters. This may sound like I'm wasting my time but I do love the 20'
My aim is to have a decent car that can switch from circuit to drift with minimal fuss and still perform. Hence why I'm looking for a decentish midrange torque + response so I can fry tyres nice n easy:P.....,,all whilst keeping the rb20
Yeh, a 2530 makes for a nice setup, but I personally think its worthwhile losing 15-20rwkws at 3,800rpm odd to make equal and more power from 4,200rpm. If you are caught in the wrong gear etc the TD06 can be a bit painful...but I feel a TD06 will make for the quicker car all other things being equal around a track, drifting or drags
But the truth is its pretty easy to spend 5k getting a TD06 setup singing so whatever you chose just do the numbers carefully before hand and make sure its the path you want to take.
Thanks for the advice, it will be well -heeded.
Am trying to work of the experience you have here to make life a bit easier for myself but from what you say I think it will be td06....am seriously pondering a kinugawa td06.....
There's just so many trims lol. Sh.sl etc, should I go 20g or 25g and which trim do you reccomend??
I think if you can get a 10cm TD05 exhaust housing then I would grab a kinugawa TD05h-18G and throw 18psi at it. I suspect you may be down 20-25rwkws compared to the TD06-20G but between 245-255rwks would be a good cross between 2530 and TD06-20G. If you get bored of the power just throw a kinugawa TD06-20G on it...but I suspect the 18G could make for a generally faster more reliable RB20
The TD05-18G comes internally or externally gated. If you can stretch the dollars I suggest going the external gate as its my opinion that the RB20 likes an exhaust manifold a lot more then the RB25 as you dont have the extra compression, variable inlet timing and compression the 25 has.
Yeh, the Dutton footage was funny. The car had a fair bit of coverage considering it didnt really factor in the placing on the event. One year when Juz was co-driving she got her own 2 min segment which meant the lil R32 got plenty of coverage :)
Right now I am trying to move around dates as I am entered in the SAU Nationals but having wisdom teeth out the Thursday before the event :(
That sucks man. 2 days is not enough recovery! Unless you plan to anethetise yourself with alcohol all weekend!
Was actually looking for something else when i came across this thread....Larv the car Roy and jjjjjesus you have some patience mate...anyway ive been a RB20 fan for years now and after a hard year of working llllong long hours and saving alot my (r32 4 door) goes into a performance workshop tmrw for a replacement engine (20 of course) and a retune with the following goodies - :worship: gtr injectors and resistor pack off of a 2004 nur spec gtr, Z32 air flow meter,apexi power fc, cam gears,FMIC,Bleed valve (4 now), 3inch zorst all the way with 4 inch tip, orc clutch and lightened flywheel,bosch 044 fuel pump, fuel pressure regulator and a genuine td05/20g turbo with turbosmart ultra gate and screamer ..I know that the td06 is a better turbo at top end but i chose to sacrifice top end for less lag and more fun sooner rather then the 700rpm to 1000 rpm later..i do have a question tho in regards to cams, i was intending to get tomei pon cams but after reading the whole 20odd page killa read im sorta in 2 minds now as if they will be worth it..? any ideas?
Cheers mate
Edited by rb.20.4ht
Sounds like a sorted package. I personally wouldnt bother with cams. I think std are fine. That said I do have some Tomei 256/8.5mm cams that may get a god in a few weeks when my car finally goes E85. Perhaps they will work, but I suspect I will lose power again.I will be sure to report back either way.
And just got back from the SAU Nationals where the car ran pretty well all day. A few little gremlins that hurt early running but car drive home which is the main thing. I think its time for a compression test to see how the engine is holding up.
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
