Stoked to have my car back ... but the plans to throw the new turbo on and go for a tune is on hold as I have a problem with the brakes which have destroyed near new rotors. So looks like I need a new pair of rotors which is going to set me back 1K so install and tune will have to wait a few weeks
yeah sounds a bit odd, unlucky. maybe look at running a different compound pad on the rear? maybe not getting up to temp and being harsh? not good anyway, hope ya sort it and dont lose another pair,
cheers
  • 4 weeks later...
With a general bad attitude after getting my car back i took to it with a 9,600rpm rev limit at a motorkhana day and took my frustration out on it. Like all good women she understood my frustration and put up with the abuse I gave her....only to awaken the next morning and regret and decide time to spend some more money on her to show much i "appreciate her " :whistling:
Teh below pics is from drifting a bend and section of straight blazing 3rd gear on the 9,600rpm limiter before braking to stop in the finishing gate. The site of smoke behind me was hilarious... it seems a std motor can take almost anything you can sensibly throw at it.
Haha, Roy!
If you are willing to test the little baby, might as well push it to 10k rpm and see how many track days it survives.
My friend has been running 10k rpm on his 2jz for 4 drifting seasons in Malaysia. And its stock crank and rods. Only forged pistons.
And I believe its still alive.
Edited by robots
I will never do it but I have worked out the pulley sizes I would need for the PS etc etc if i tried to spin the RB24 to 10,000rpm. :) With the solid followers, titanium retainers and Tomei springs then you would think if it was bolted together right then you would be able to spin it to 10k. The little 82mm pistons weight far less then an RB26 piston. The valves are smaller and lighter...problem is my patience and curiosity with trying all this stuff is getting a bit thin and as much as I want to do it I think I need to flog off all my gear and stick with std motors. If they pop then who cares...$600 and soeme spare dosh for some tidy up love and I can be back to having fun with next to no outlay
Started to pull the Cossie down today and seems a good thing. Mahle pistons, AP clutch, plenty of porting in the head. So throwing some new front and rear main seals at it. Some fresh bearings and hopefuly have it all back together and tuned up in the next 3-4 weeks :)
With that grey area cleared up...I need to think long and hard do I sink money into trying to get my current setup working with E85 and then try the new turbo to see if I cant get 300-320rwkws out of it...or do I just leave it as is and spend that money on a sump and the machining / assembly of my new engine?!?!?! I want to hit 300rwkws out of a std RB20 but it looks like its going to cost too much money trying to find what is limiting the current setup. Inlet piping, exhaust piping, exhaust housing diam??? f**k knows :)
For experiment purposes why don't you lend some haltech or other map-based plug-in ecu.
You will remove intake restrictions that way. Next step make a temporary 4'' exhaust elbow. Straight down to the ground or something. Nothing fancy.
Start with the setup the theoretically could get the largest power gains. Start with the largest AR on the hotside you have there, maybe even cams, billet wheels, pump E85 blood in there and smash it with 30psi)) It should work. Analysis is as good as the data, right ? )) Just go berserk on it :)
That's always been my thinking!
What will you enjoy more? Talking about engine internals blah blah or getting the thing on the track!?!
Hey, 25Fanboi....Will I be kicking your ass at PI at end of June?
Haha. Yeah I put in my entry today. Was hoping to do testing the PIARC weekend before but I'm working so signed up for the alfa day 30/6.
Unless your AFM is maxed out it won't be a restiction. How much timing are you running? on E85 it sould be in the range of 25-28deg.
A circuit car down here made 290rwkw with a stock 20, and one of GCG's internal gated GT3071r on a standard ex manifold with E85.
Might be time to get a nice modern Garrett.
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
