Sorry I miss read about the 25det crank.
Why the low rev limit. Mark 1 of my 25de revved to 8 and mark 2 revs to 7400 due to fuel supply.
With 320rwkw it was happy to bang limi all day it wasn't revs that killed it anyway.
And there is bugger all difference in the cams mainly the cam timing but that won't stop it revving
I think its the exhaust back pressure at high rpm, cam timing and cams...a little bit of everything. The RB20 actually makes more power as the new engine falls over after 6,500rpm
So will try new turbo with bigger housing, going for the 12cm2, cam gears, cams etc and I am pretty sure will find a bucket load of top end. Will throw the 20G back on to compare to see if the billet turbo is any better. I think the 20G could be a good thing if we can get it breathing up top and get it to hold onto power. A solid 4,000rpm range of 300 odd rwkws would be pretty solid result
The 12cm housing shall at least enable me to flow plenty and see what the compressors will flow
Yes, the character of the 2L is more fun. Will be interesting to see how is goes for traction at the track when driving in anger
Phillip Island in late April. Trying to get my new suspension and rear end in for it so that I can throw in my new gearbox. I have to put the rear end in with the gearbox otehrwise will need to do the tailshaft twice. Gearbox feels fine but concerned it will have trouble with the torque of bigger engine on E85 with more power and track work. it has done 210,000kms but at the end of the day not "not going to go" because of functioning RB20 gearbox may let go
If the RB20 didnt split that heater hose then i would never have put this engine in. This was the "too cheap to pass up in case I got EPA'd engine" that I hoped would never get used.
Anyway. So after a Saturday of wasting Racepaces dyno time with fiddling with the 20G and 12cm housing...we are pretty sure we have run out ofcompressor but simply couldnt get thet thing to hold boost.
So knowing the Hypergate only had a piss weak 11 psi spring I have grabbed 3 more springs and should be able to find a good combo to get the gate to hold about 19psi...and us bleed what we want from there.
So cam gears are in. Tomei 256/8.5mm cams are in. 12cm housing on. 19psi springs in the gate and she is rolling onto the dyno still with the 20G as we speak. Plan is to get a good baseline for the 20G to back to back with the T67 and 73HTA.
All this testing is a ball ache, but the engineer in me loves it :)
I must admist I was having long , close looks at your car. I really like how you have done htings.
I think there is a definite thinking to how to build a car when you are a frustrated engineer that wants to drive and build cars for a living :) Not always the easy way, or the quick way OR the the cheap way....but he cool way :thumbsup:
Engine is meant to have new GTR valve springs. No signs that there is anything wrong with the engine at the moment, Seems all setup related. Not really a problem...just a combo not really working well together....which is to be expected when you throw 500cc at a 2L setup.
request thread title change to "A boy and his hatred for 350+ rwkw RB25de+t because broken in the head"
I am with you...the only thing that helps with the disdain I have for this motor is that its cheap and looks like an RB20, so is 2/3 the recipe of an RB20 :)
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
