All gone I unfortunately. All i have is a TD05-18G laying around
What were the Kinugawa like?
I can get a T67-25G with trust housing from them.
The brand whore in me says stay Trust.
But it's over double the price.
Not keen on getting the L2 modified.
Will either swap for a Trust T67 or keep I for a rainy day.
My Kando is new so cant really comment. Having ran a TD06-20G 8cm and T67-10cm in my RB25 i petsonally suggest you get a 10cm housing fot your L2. On E85 eill make a fat 310rwkws...made for a way faster street car then the T67. The one PI day i did with the T67 it was a good thing good  mud and strong top...but on the street the 20G was waaaaay punchier and pulled way harder in tbe mid to top...just lacked that extra 50rwks after 6,500rpm that the T67 happily saw up top to 8,000rpm
That's my concern. Too small for the 2.5L.
The L2 with 8cm rear should make 315 according to the trust book.
Compressor side is the issue. Cropped wheel and all.
45 degree curve and out of puff very early I believe is what to expect.
Perhaps just go with it and see what it does on the dyno?
  • 4 weeks later...
  • 1 month later...
  • 6 months later...
On 11/13/2018 at 9:28 AM, Roy said:
So...this will keep me honest...
Thanks always to Racepace for being able to make a bunch of mismatched parts cobbled together work so well
That’s some nice streetable horses!
So 2 days at Bathurst didnt go to plan. Slapped enough stuff together to do only 1 lap. Fuel filler tank kept spewing fuel meaning meatball flags. Then had a few other small similar things go astray...and ultimately fixed a few things on the fly that called into question  othet things that need a dyno run to work through so only did a lap at gate pressure
Running twin GT2860-5s
T
So looking back a week later now I feel frustrated. The first and only lap was a rather leisurely lap and not bad at 2:42 all things considered.
Wish I could have gotten another 3-5 laps as I think I would have gotten it down into the low 30s or high 20s rather quickly. After that its going to take a load of laps to get anywhere near the limit....but not even worried about that. Its definitely a place where you need to treat it like a tarmac rally and appreciate that a pinched brake may mean a horrible table top ride back to the pits :(
Anyway...over the next few weekends will need to fix the stoooopid filler neck. Fuel tanks check/roll over valve and stupid radiator shroud that decided to crack and meet the viscous fan. Stooopid old cars and meatball flags! ?
  • Like 2
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
