  • 1 year later...
On 11/27/2018 at 9:27 AM, paulR32gtr said:
My filler neck is toast too... get me a new one while you are at it!
On 1/19/2020 at 3:43 PM, Roy said:
Post to follow
What you finally got my new filler neck did you?
  • 10 months later...
Well , after a break in and some scum bags stealing a lot of gear from the car I have finally got it back up and running. Took +12 months to replace stolen parts and work around Covid...but....Just in time to make Bathurst last week
Tidied upo the engine bay, freshened up the head with some light headwork, new headgasket and oil pump, sump and a lick of paint.
  • Like 3
Ran out of brake pads with two sessions to go so missed the chance to have a proper go after getting familiar with the layout and the car...but oh well. There is always next year.
You can see the lines of pad material that fell out of the wheels when I returned to the pits.
  • Like 4
Sorry to hear about the scumbags, it's something we all fear but glad to see this thing back running again and getting out there where it should be. Looks and sounds great, love those rocker covers Roy, they're awesome 👍
  • 3 weeks later...
What sort of times does this thing do at PI? Planning to do any days down there this year? We can compare notes to see who has the best 'RB20' in an HCR32. I did a shake down at Winton late last year and managed a 1:34 so hoping to crack the 1:40's at PI.
Was this the bus that George got to have a steer of?
You'd be miles quicker if you are aiming for 1:40  at PI :(
Back around 2013 was my last time at PI. did a 1:48.6 from memory with 260rwkws and was still on 98 and the old engine. I O ly did two laps on E85 and I was 20km/h quicker on the straight but the  front right kingpin bearing collapsed middle of turn 1...that started the 7year rebuild of all the suspension a d driveline
Was going to PI this weekend but last weekend at Sandown revealed I need to fix a few things...some as stupid as needing a new dipstick :)
I think my best at Winton back around the same period was 1:36.9 or something. I did a sub 1:36 at a Friday on RE55s but not on Natsoft so doesn't count :)
https://youtu.be/m5KcwIN2kKI
  • Like 1
Haha, no I meant any time starting with 1:4x.xx! Under 1:50 is quick enough for a full weight RB20 powerhouse I reckon.
I won't be down there any time soon though, still waiting for the dry sump components from Ross to be made and posted.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
