No problem. Appreciate you looking for me though.
Start new job in January....will be good to be back in Melb, no more 70hr weeks at a start up...normal programming shall resume. 2023...hopefully my 18yr quest of a teen at Sandown is realised :)
  • 3 months later...
So just got back from a few days in Tassie.  Was a great trip that included some laps at Symmons Plains and Baskerville
Finally started to get the car sorted, though the borrowed GoPro proved to be less than great
https://youtu.be/5oVTdOG7svM
  • Like 3
And Symmons Plains vid. God I was losing time under brakes and off the start finish straight. Tough place to work out whether its 2nd or 3rd. Anyway...good fun. Baskerville was better seat time and started to get my head around driving the girl after years of little driving
  • Like 3
  • 1 month later...
Of course. Never getting rid of the old girl. Sandown went well yeterday. Definitely need some new tyres as they are rather square now :)
PB with a 1:19.77
Not happy with the 4.1 diff and need to go back to 4.3 ratio. But good to be consitently getting some laps in the car as I still suck
  • Like 3
  • 1 month later...
Its a shitbox too...The Motec and EFR sitting on the bench will hopefully help it break more driveline parts :)  Christ, had it 12 years . Time for another English shitter
I should actually swap beakes. 370mm 6 pot APs for street car and 343mm 4 pot on club car!?!?!? 🤔
  • Like 3
17 hours ago, Roy said:
I love my old school Weds but having used a set of Pagid RS29s and rotors down to 30.5mm after only really 8 track days I think it's time for 18s :(
Nope, keep the purity wheels and just change pads when you need to. Depending how many session you did, 8 days is a lot of work.
Plus, tyres in 17s are cheaper and more compliant than 18s for the same diameter.
Yeh,  I found a place that does 68 vane 343mm rotors so hoping going from 42 to 68 with some better ducting will keep them alive
For all those reasons I have kept the 17s Uncle Dunc....32s just don't look as good with 18s. But the 343mm does limit the 17" wheels you can run to basically LM GT4, TE37s or Weds TC
You Bathursting this year?
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
