your best bet would be to contact Wolf, see if there is anyone near your area that can tune them. If not, would be a silly idea to put one in.
i believe wolf's website has a list of authorised workshops or something like that.
https://www.sau.com.au/forums/topic/330620-wolf-v500/#findComment-5371735
Sweetas, yeh my mate paid about that but seeing as he has no car anymore and is not planning on buying another one he just wants to get rid of it. Yeah there is a guy in townsville who loves the wolf v500 and tunes heaps of cars with them in it.
https://www.sau.com.au/forums/topic/330620-wolf-v500/#findComment-5378677
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
