ylwgtr2 Posted July 29, 2010 Share Posted July 29, 2010 (edited) For RWC he picked up: rocket cover gaskets its rocker or cam cover dude Edited July 29, 2010 by ylwgtr2 Link to comment https://www.sau.com.au/forums/topic/330633-action-against-dodgey-rwc/page/2/#findComment-5372177 Share on other sites More sharing options...
PIOTREK Posted July 29, 2010 Author Share Posted July 29, 2010 lolz good sense of humor Link to comment https://www.sau.com.au/forums/topic/330633-action-against-dodgey-rwc/page/2/#findComment-5372334 Share on other sites More sharing options...
Cowboy1600 Posted July 29, 2010 Share Posted July 29, 2010 Firstly it's MECHANIC. Right. Secondly, none of this sounds RWC related. The water pump siezing was definitely no fault of the mechanic nor an RWC item. And believe it or not but oil leaks CAN manifest "overnight". There is a chance that perhaps he didn't install something correctly when he did the gaskets, in which case, shit happens. There was unlikely to be any devious intentions and so long as he rectifies it, then no harm done. It's not an RWC item so suck it up. As has been said, an RWC does not guarantee you haven't bought a shit car. Sounds to me like you bought a lemon and the mechanic has actually done the right thing by you and not pinged every little thing he could but now your lemon is being squeezed you want someone to blame. Link to comment https://www.sau.com.au/forums/topic/330633-action-against-dodgey-rwc/page/2/#findComment-5373386 Share on other sites More sharing options...
saff_cossie Posted July 29, 2010 Share Posted July 29, 2010 What? So the wall was gone? How was there air in the tyres? How do you know something didnt happen to them in the 2000kms of driving??? It was verified by a further 2 independant parties, both who I didn't know prior. The damage was consistent with wear over a duration not hard impact. There was another part to it which will type up later where we were able to confirm it occuring it over a duration and not quickly. Walls wise, could put my fingers into the deep scoring as the wall had collapsed. Link to comment https://www.sau.com.au/forums/topic/330633-action-against-dodgey-rwc/page/2/#findComment-5373874 Share on other sites More sharing options...
PIOTREK Posted July 29, 2010 Author Share Posted July 29, 2010 Firstly it's MECHANIC.Right. Secondly, none of this sounds RWC related. The water pump siezing was definitely no fault of the mechanic nor an RWC item. And believe it or not but oil leaks CAN manifest "overnight". There is a chance that perhaps he didn't install something correctly when he did the gaskets, in which case, shit happens. There was unlikely to be any devious intentions and so long as he rectifies it, then no harm done. It's not an RWC item so suck it up. As has been said, an RWC does not guarantee you haven't bought a shit car. Sounds to me like you bought a lemon and the mechanic has actually done the right thing by you and not pinged every little thing he could but now your lemon is being squeezed you want someone to blame. Look apart from the smallish leak the car is perfect and I said earlier I’m playing the blame game as I’m really happy with the car! Don't mean to be rude but I’m not asking for your "opinion" what is an issue and is not. I said earlier that I was just wondering what the law in this situation is IF the rwc is dodgy. This has now been resolved so there is no need for you to further try and dig deeper into this. As for the RWC pump seizing was just bad luck and coped it on the chin. Doesn't mean the car is a lemon as the pump was not leaking! If you pay a decent shop to change gasket and they continue to leak (due to poor labour), then most places will attempt to fix the problem free of charge, to protect the rep ( i checked and this was not the case this time) If you wanted to actually contribute to the discussion you could say the rwc rule about oil leak as I’m sure it defined somewhere. But like I said I got everything under control, thanks for your input. Link to comment https://www.sau.com.au/forums/topic/330633-action-against-dodgey-rwc/page/2/#findComment-5373961 Share on other sites More sharing options...
Cowboy1600 Posted July 29, 2010 Share Posted July 29, 2010 Look apart from the smallish leak the car is perfect and I said earlier I'm playing the blame game as I'm really happy with the car! Don't mean to be rude but I'm not asking for your "opinion" what is an issue and is not. I said earlier that I was just wondering what the law in this situation is IF the rwc is dodgy. This has now been resolved so there is no need for you to further try and dig deeper into this. As for the RWC pump seizing was just bad luck and coped it on the chin. Doesn't mean the car is a lemon as the pump was not leaking! If you pay a decent shop to change gasket and they continue to leak (due to poor labour), then most places will attempt to fix the problem free of charge, to protect the rep ( i checked and this was not the case this time) If you wanted to actually contribute to the discussion you could say the rwc rule about oil leak as I'm sure it defined somewhere. But like I said I got everything under control, thanks for your input. Do you actually know where the oil leak is and what caused it yet? Link to comment https://www.sau.com.au/forums/topic/330633-action-against-dodgey-rwc/page/2/#findComment-5374085 Share on other sites More sharing options...
PIOTREK Posted July 30, 2010 Author Share Posted July 30, 2010 without degreasing the the engine yet (which i will do over the weekend) i know the cam and crank seals are fine and the rockets are good too. there must me some small hose that has come loose and its frustrating not been able to locate the leak lol maybe some sort of breather.... Link to comment https://www.sau.com.au/forums/topic/330633-action-against-dodgey-rwc/page/2/#findComment-5374161 Share on other sites More sharing options...
