Random Parts Shed Clean Out
Hey Guys
Got some random parts for sale I don't need and need gone!
Need to make way for the project car
I'm located Southern Suburbs of Adelaide
Willing to post at buyers expense
PM or txt 0403 642 517
S14 ABS System and Bracket $50
S14 Clutch Master Cylinder $30
S14 Automatic Brake Pedal $10
S13 / 180SX Climate Control Unit $80
R31 Rb30 pacemaker extractors with nuts and Oxygen/O2 Sensor $100
R32 Climate Control Unit $30
R33 Climate Control Unit x2 $30
R34 side clear indicators with bulb and plug 1 is scratched and cracked the other is good X2 $20
CA18 Low Mount Stainless Turbo Manifold $100
1 super steel 595, 205/40 R17 98% tread
The rest off these parts are off a 1992 NX-R throw me an offer
4 auscar rims 16' 4x71mm in average condition
Full set of wheel nuts and lock nuts
NX-R caliper kit front and rear (I payed $98) $50
model number (41120 11L27)
L/R 1992 NX-R CV's about 70000k old
2 x sr20 distributors 1x has a broken distributor cap (80000 km or less)
Sr20 coil pack (80 000 km or less)
Sr20 coil pack module (80 000 km or less)
NX lower control arm no ball joints
2x NX boot light's
+ Battery terminal
Pod filter
Razo racing pedals
thanks
 Share
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
