are you sure you're not thinking of RB25 side feed injectors? this is like all the people who keep saying sard 700s don't fit RB256 fuel rails etc... they do.
I think this is the problem....i believe the the nismo 555cc yellow rb25 is 4 hole and the nismo 555cc pink rb26 is single hole....I have a set here and want to confirm if they indeed nismo... they are rb26 top feed type, Jecs, pink, single hole...hence i asked the question as i "heard" they suppose to be 4 hole
Nismoid...
Does nismo even make a 660cc top feed rb26 injector??? I think it was just 555cc pink and 600cc purple
Any way see if you get those pics
My car ended up making 296kw on 19psi pump fuel.
Then tried for e85 and maxed the injectors and setup at the same power.
I never actually check the nozzle. My bad.
What duty were you seeing with the 600cc @ this power on 98?
Michael im unsure of exact specs of my turbo's or wastegate actuators. I was told by the previous owner he got them off SAU as rebuilt to N1 spec turbo's.
My car loses 1psi by redline But i set my boost controller to have a slight spike
My injectors were at 75% from memory on high boost at 11.6AFR
    • From my bolts, standard M8 with 1.25mm thread pitch (M8x1.25mm).    Length is 19mm under the head and has a captive 18mm OD flat washer.   20mm length from a bolt shop is what you'll be able to get.   Make sure they're zinc plated.    If you're concerned about strength, grade 8.8 will be more than enough. Original PN is 01121-04971.  Now discontinued according to Amayama but that's because it's one of the parts that's been captured by the Heritage program, which explains the ridiculous price.   New PN is 01121-RHR20: https://nismodirect.com/nismo-heritage-bolt-pin-hinge-hood-bnr32-nissan-skyline-gt-r-01121-rhr20-01121-04971/ About AUD33 converted from Yen in the above link but that's just one example. Interesting that the hinge-to-body bolts are still available non-heritage.....PN 08116-8161G around $2 each (amayama).    Same thread but 16mm long.
    • Well, if that filter was impeding fluid flow, then it could have similar effects to faulty solenoids. The TCU will register a fault when it does something (ie, changes the state of a solenoid) and does not detect the required result. If there are other causes that can make the same lack of result, then they will be indistinguishable to the expected cause for which the TCU has a code.
    • Yellowjackets, red ones, blue ones (other than Splitfire) have all been demonstrated to be unreliable on turbo engines. That unreliability can be anything from outright failure (ie, 4 out of a set of 6 working out of the box) to just not being strong enough for the task, on a boosted engine. Not enough of us care about NA engines to know whether that unreliability is an issue for the undemanding needs of an NA RB20. I should think though that the DIS-008 should fit the 20. There's not really any reason for the head/coil mounting area to be any different on those 2 Neos. I wouldn't be buying Splitfires, or any other old tech coilpack, for a car in this day and age though. I would buy modern pencil coils and do what needs to be done to adapt them to the loom. That's relatively trivial these days, with numerous kits for fitting R35, or Audi, or Yaris/Corolla coils.
    • Keen to see how much work is needed to get an abandoned Skyline going. My R32 has been sitting idle for three years or so but finally got some time to get it going again. (Also lurking SAU and trying to hit 10 posts so I can start my own intro thread with pics)
    • Hi. Which coilpacks can i use in my engine? I looked at the Splitfire but the closest "match" i found was SP-DIS-008 but even that they do not show RB20DE NEO so iam not 100% sure. Or maybe different one which will 100% work? I saw many on ebay but they are some cheap "strange" ones. What about Yellow Jackets? Many thanks 🙂
