help, I went to get grocerys and when I went to drive home, started the stag up,,, it idled really low and was fighting not to stall, then cleared up but wont go over like 2.3k or so,, just like its hitting limiter,, really nead help guys
https://www.sau.com.au/forums/topic/330649-help-engine-wont-go-over-2k-rpm/
  • Replies 42
Sounds like you need to visit a tuner mate. Tell them the symptoms and they can plug in their diagnostic software and suggest the fix.
Another method is to borrow someone elses AFM from an M35 and plug that in place of yours.
Moisture in the AFM?
I'm not sure about M35's but most AFM are hot wire. They have a limited life due to the thermal cycles they go though. You might have even gone over a speed hump and it may have broken. The only way you can find out if they are good or bad is diagnostic software or replace it with a working version.
more than likely it's the AFM....mine died two weeks ago for no reason as well.
Get the codes.....pretty sure you can get an second hand x-trail one.....or you can go for the 1 year warranty approach and buy a new one....Hornsby Nissan had em in stock....get a price from them I'll see if I can beat it.
Thanks everyone. Fault code 0100. Took a couple of tries to get it to flash, bu got it in the end.
Now to see about getting a new afm. Anyone know where is good to go? Nissan is one. Any other.
I have an s2 afm I'm selling I'll pm u
Arnt wc34 and m35 different?
some of the C34 guys get a little confused.....I give you a heads up as they don't quite get it :nyaanyaa:......our car is 98% different to the C34! So when you hear the line "Well on my C34......" more than likely they are completely wrong with the assessment!
Sorry in advance if I have offended any C34 owners :P
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
