  • Replies 42
help, I went to get grocerys and when I went to drive home, started the stag up,,, it idled really low and was fighting not to stall, then cleared up but wont go over like 2.3k or so,, just like its hitting limiter,, really nead help guys
AFM.
Nm35 Died Mid Flight, anyone had this? - its tricky
We don't get offended since we have been making more power for so long that we are genuinely happy every time you guys crack a little more power than stock...... :P
AFM = Air Flow Meter
MAF = Mass Air Flow
AFM = MAF
..ahem..a little more power? i think scotty and jetwreck have both achieved a bit more than a little :)
I'm surprised no-one has bitten on this comment, as I run into all the time I'll end my rant now :/
Everyone was a bit slow to bite there Bis.
Since generalisations were being thrown around I thought.....what the hey. :/
really!....thanks for that!
Sorry Jet that was being directed at whitestag's query. (I'm pretty sure you are saying derr)
lol.....I did write a couple of responses.....but there is no real come back.
Your right....heaps of parts straight off the shelf to build a decent tractor motor....sorry RB.....hey after 20-30 years of the motor being on the market getting 270 AWKW's reliably out of one of them without cracking the motor open and with the same turbo housings should be easy aye!
lol.....how did we get here from AFM :/
Edited by Jetwreck
Yeah, but isn't that almost what Scotty is doing anyway?
Funny thing but AWKW and RWKW readings are almost always identical unless there is wheel spin. Sure people add 10kw or so to their figures but I take that with a grain of salt...in fact all dyno numbers as well.
The R33 is in RWKW cos it only has one diff and doesn't struggle for traction (in a straight line at least). Obviously the stagea was missing its front driveshaft for the dyno runs. It grips up fine with it back in.
all good, went over to northshore,, they checked it and replaced the MAF and all good,,, ready for some spirited driving again...
Thanks for all your help everyone.
now onto that dump pipe..
Edited by whitestag
some of the C34 guys get a little confused.....I give you a heads up as they don't quite get it :( ......our car is 98% different to the C34! So when you hear the line "Well on my C34......" more than likely they are completely wrong with the assessment!
Sorry in advance if I have offended any C34 owners :P
98% different hey?
I was going to say: "Well on my SR20......" I was right anyway, despite the fact that I own a 4 cylinder. BAHAHhahahaha.
AND it still ended up being the AFM!
98% different hey?
:D what error code comes up and how do you get it with your SR20!
here's one for you.....the C34 has a shit load more in common with a R33, R34 yes?....or would you say the C34 has a lot more in common with a 350Z!
and congrats on the diagnosis........your a rocket scientist aye! :)
Edited by Jetwreck
I've got the factory MIL light on the SR20 fitted to the 1600. Never use it though.
I just plug in the nistune software and it tells me the fault codes. Pretty easy and highly recommended.
C34 has a motor in the front and so does the M35. Both are made by Nissan. Both have an AFM and by the sounds of it, have a limp home mode. That's enough commonality for me :bunny:
Rocket Scientist? Nah, just willing to help a nissan brother out...
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
