looking good mate!
they're actually grenade GX01 rims, not R34 GTR as stated on the last page :D
ah, useful bit of info that one, thanks for that, (i did say replica though :))
The car looks great !! I love what u did with the interior , how hard is the interior to do ? I wouldn't mind trying tha my self ??
Thanks dude, Sadly i have since removed it all since it started to peel up when the interior got hot (im 90% sure its because of the paint on the trim i applied it to) I am now contemplating 1 of 3 options.
1. Coating the trim in Clear a few times and then hitting it with the cf vinyl again in the hopes that the clear will provide a better base to adhere to
2. Stripping it back and re-spraying it in VHT Black Crinkle paint
3. Saving up and replacing the interior piece by piece with real Carbon pieces from Superior Auto Creative
  • 3 weeks later...
  • Replies 161
Again, it looks really good, Stephen. Great work. :thumbsup:
Thanks Victor,
Been set back a touch with doing the retrim on the doors, need to figure out a good way to remove all of the old foam that was under the material, that stuff is stuck on so damn well, metho cleans, but doesnt remove the foam as such.
I'v decided to do this to a side project. how do you join 2 peices properly?
some area's have taken a long time and many re-tries such as mirrors.
I'v stopped caring about little creases and once completely covered will redo them maybe.
my thumbs hurt..
what do you guys charge per hour to do it professionally, I'm not in brisbane though just curious.
Ok guys, bit of an update here,
Finally solved my problem with the foam on the door skins, the best solution was to take the skin off the door, and lay it flat, then with a scuffing pad scrub the crap out of it until the foam eventually all came off (forgot to get pics of it at that stage)
after that, a blade around the edge took off any of the excess bits in the recess.
Also, before i attacked the foam i figure, whilst the door skin is off i might as well wrap the window controls and also the triangles in the corners of the door where most people mount a tweeter.
TRIANGLE
PASSENGER WINDOW CONTROLS
This is what the drivers door looks like at the moment, with all of the excess foam all over it, Horrible! (will attack this door tonight)
Then, these (and a scuffing pad that i forgot to include in the pic)
Added together =
And all back together retrimmed skin with carbon-ized window trims and triangles
Stay Tuned!
So putting a little attention towards the interior, :)
Also worth noting, the bootlid has been re-glassed, as long as it doesnt crack or have any issues in the next few days, itll be getting primed and paint hopefully during the week, and then wrapped maybe around sunday *fingers crossed*
ive got the carbon fiber dash aswell
i just dont have the ac controls and the vents carbon fiber were can i get that
http://translate.google.com.au/translate?hl=en&sl=ja&u=http://www.superior-cia.com/&ei=tzchTYbGAsrCccjD_bQK&sa=X&oi=translate&ct=result&resnum=1&ved=0CCcQ7gEwAA&prev=/search%3Fq%3Dsuperior%2Bcia%26hl%3Den%26safe%3Doff%26biw%3D1680%26bih%3D860%26prmd%3Divns
These guys do most interior parts in carbon for R34's, a little experimenting will get you to the right section for the parts.
That said, those pics you quoted are what i wrapped in carbon look vinyl, so they aren't real carbon.
Little side project while i haven't been working on the 34
http://translate.goo...0%26prmd%3Divns
ohk so u done the top part with a carbon look a like sticker ?
this is mine ..
this is mine ..
ah nice, yeah i did the whole lot with carbon vinyl, except the triple gauge cluster.
where did you get your carbon bits from?
thanks..
i got the car like this
yea i think the gauge cluster would look abit odd carbon wouldnt match the dash
  • 1 month later...
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
