Hi Fellas,
On my way home from work I gave my car a little squirt... and it ran fine...
I gave my car another squirt and the turbo didn't sound nearly as loud, the turbo was making a very different pitch and smoke was coming from around the turbo housing when I opened the bonnet.
The turbo still makes full boost, but the car isn't making the power it used to, and the turbo sound COMPLETELY different.
Not sure what it could be? I check all the pipes and stuff that was all fine....
If my turbo was blown it wouldn't be making boost?
Also, not when I hit it the car backfires sometimes under full load...
Has anyone ever experienced such symptoms, or has any idea what it might be?
Thanks.
https://www.sau.com.au/forums/topic/330678-i-think-my-turbo-has-died/
any unusual smoke from the exhaust.
have you pulled off the turbo inlet to check the turbine, see if it spins freely etc.
does the engine tick when you rev it with the bonnet up?
might just be a blown turbo >manifold gasket
If it's a stock turbo, its possible part of the ceramic exhaust wheel has chipped throwing off the balance of the wheel. If the turbo was completely blown, it would revert to being N/A, and you will definitely know powerwise (low compression N/A RB anyone?)
Check the cat hasn't melted/blocked up, and check for snapped studs on the manifold and turbo
Its an RB25/30 with a GT35r.
It's not the cat because I am running a straight pipe.
There has been no smoke from the exhaust at all, which makes it even more unusual....
When driving off boost and idling, the car sounds fine, it's only when it's under full load it start playing up....
Ill bull off the intake pipe when the car cools down to see if the wheel spins freely.
Thanks for your suggestions but, keep them coming!
leak in cooler or cooler piping, i had a leak in one of my joiners and it made the same boost, just felt like something was wrong
Could be the cooler piping, but then again, there was some outrageous smell coming from the turbo housing with smoke?
meh... just empty it and see how quickly it refills. then you can start worrying if its full pretty quickly
What's the "standard" if you'd like for how fast it should fill up?
I drive me car everyday to work, and quite a bit on the weekends, and I do push it quite a bit (that's what it is made for?)
Would it be bad, lets say, over 2 months for 600ml to fill up in the can?
Keep in mind its a performance vehicle running high pressure (RB25/30 with GT35R running at 23PSI)
That sounds like a decent amount of oil to fill a damn 600ml catch can in 8 weeks of driving on the street....
My car gets maybe 1mm of oil in the bottom of the catch can every time I service it which is around 6 months no matter how hard I drive it including mountain runs sitting at high RPM for 8 minutes up and down.
Curious to see what other people say :D
Edited by PM-R33
Some engines breath heavier then others. Especially at 23 psi with a 35r.
Not worth worrying about it.
Could put a drain back to the sump from the catch can.
Have u done any oil control mods when u built the motor?
One of the main issues with a bit of blow by is the fuel vapour breaking down the oil which then doesnt lubricate as it should.
So try not to miss an oil change or maybe even change it more frequently.
Obviously ur running forged pistons which when cold are even worse at sealing in compression. So let it warm up to operating temp, not just water temp but oil aswell, before u boost it at all.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
