Have searched the forums, but haven't found a definite answer for NA R34 coupes. I've found varying answers but mostly for GTT''s, sedan variants or R33's.
What are the part numbers for the front/rear brake pads, for the R34 25GT coupe (not GT-V etc)?
https://www.sau.com.au/forums/topic/330716-r34-25gt-coupe-brake-pads/
Get your self some QFM brake pads.
dont know the part numbers, but shoot an email to [email protected] and tell them what you have and they will had a pad to suit.
IMO much better than anything bendix put out, less brake dust and much better pedal feel.
  • 9 months later...
It was hard for me to buy brake pads for my R34 25GT other then from nissan... everywhere i went they cross referenced me to the GTT rotors and brakes... then they matched up my brake pads with some mitsubishi 4x4 (really similar)... i ended up going to nissan (paid a bit more) because i couldn't be stuffed handling with incompetent people, I would of ended up punching them (I was sent to 4 different repco's to pick up the wrong parts all in one day)! pinch.gif
How much did you pay for the pads from Nissan?
Its a complete Mission to find almost any part for a NA R34 just another negative of owning this car and because of this i find myself putting off fixing up certain faults, brake pads need changing and i might need to go to nissan and pay a premium price im guessing and wait a while like i did for one bearing that took over 2 weeks, so a clarification on aftermarket Pads will really be great if there is any 25GT couple owner out there knows both Rear and Front setup for a coupe 25GT :worship:
I did these last year. Went to supercheap or autobarn. This was correct:
Front DB 1308 (same as Mitsubishi Triton ute, Nissan Maxima A32, A33)
Rear DB 1144 (same as Nissan Maxima)
^ that is 110% correct for non-turbo R34 GT (excluding GTv, GTt, GT-R).
I posted that stuff a while back. :P
But honestly - if the price difference is small, best go genuine.
I know you did a good job, but there were 25GT owners who swear the pads were the same as a R33GTS and then i had you and some people claim the maxima pads, very confusing but i got it done and can say your assesment on the pads is right.
  • 6 months later...
Anyone know rotor sizes?
I've measured The front about roughly about 285mm diameter and about 26mm thick.
If you go on the dba website it has the r34 gt rb25de as on option (surprisingly) but it shows it as 296x30mm.
Can someone please clarify?
  • 3 weeks later...
I eneded up going Genuine Nissan.
The guy at the dealership told me the rotors are the same as 350z (non-brembo), Maxima and V35 Skyline (non-brembo) - But honestly give them you R34's VIN and they can definately say.
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
