there are some metal covers inside, if you take them out you get a bit more light out of them
they are fogs so it'll always be a wide spread
i was thinking about getting some driving lights for below them or maybe next to the number plate tho
i actually had the lights on each side of the number plate which im sure are a dayz option with the kit...they were pretty
cool but got sacrificed for the intercooler...
Yeah I have those plus the ones in the front bar, ones front bar are yellow, bottom ones white
i heated of my outer lenses with a hair dryer then took out the two inner lenses, one clear the other orange to get the full
light spread. now the normal halogen light colour.
same, then i got some "5000k" halogen bulbs
basically normal bulbs with a blue coating
not as blue as the xenons, but a lot whiter than the stock bulbs
seen these in the shops?
save drilling into anything.
http://www.aunger.com.au/new-product-dlights.html
Interesting, thanks guys :D
I'm also going to look at fitting some big spotties as off the clock down country roads at night.. I want to be able to see more :)
oh yeah regarding on bubba's comment on replacing driving lights, no.
found the one's in the grille quite good.
in saying that got a pair of nice 100w spotties out in the garage been boxed away for years new unused (gift).
similar size and shape to the cibie's on the dayz s2.
been eyeing of that aunger thing and umming/arrrring if i really need to get it and fit them.
Pipster are you talking about the yellow fogs in in the front bar with your indicators? I would like to do this and make them white if they are the ones you guys are referring too the yellow some how makes the car look more dated to me
4got to say, where some leather garden/rigger gloves, glass gets very hot. :D
sure am
put them in the oven with the temp on low ~80*c then slowly pull the lens off
once open, there is a yellow tinted glass in front of the bulb that just unscrews and comes off
I threw my Fogs in the Oven after Preheating to 90c for 10min, the lens came off VERY easy with the help of a flat blade screwdivers.
I removed the Yellow Glass Filter + the Amber Filter for the indicator.
Recently installed 50 Watt 6000k HIDs in the Fog lights, Looks A MILLING DOLLARS!!!
I cant stress how much better it looks. IMO... :)
Just did this to a mates Stagea aswell.
That I have seen,read and heard, we're the only 2x on the coast with HIDs in the Fogs :P
Edited by JDM_Spirit
that's my next plan :).
been keeping an eye out on the auctions for genuine ballasts to put in.
I cant stress how much better it looks. IMO... :P
That I have seen,read and heard, we're the only 2x on the coast with HIDs in the Fogs :(
which hid kid did you use?
its pretty much the only way to get the bulbs the same colour as the xenons
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
