  • Replies 69
cut the chat. faggots!
EDIT: okay!!!!
V series sedans are now welcome... sorry guys didn't think you would be interested in coming with us!!!! more the merrier!!!
okay so now this is a JDM / Imported SEDAN cruise... Nic I am hereby appointing you as my gobetween for antilag guys...
please promote that it's predominantly for nissans.. but toyota guys can join in too!!! but PLEASE drive the point home to them that this is a NO FUNNY BUSINESS cruise. any monkey time or foolish behaviour will most likely be reported!!!
it is merely a nice drive to floss our cars and drive in a line
can we please get the guy from RM photography on board for this too?? i would LOVE some SWEET photos...
hopefully this could be a decent turn out?
EDIT: tonight i will make the map. and officialise everything. it's really happening guys!!!! a bit of pee just came out.
Edited by Mr Eps
Guys don't really worry about how many people are 'confirmed'. At my last cruise I had 6 people express interest, ended up getting close to 50 cars show up. Just remember that there are a lot of people that will tell their mates or sit in the shadows and not post anything. This cruise has been posted on a number of sites so I'm sure you will get a good turnout Rowan :)
less chat.
also. i got the arvo off cos my boss is from northam and it hit a chord with her that i was travelling out there.
ps - what an amazing drive. i've NEVER seen so much grass!!!!
next sedan cruise will be out to toodjay - lovers lane here we come :)
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
