hey have my second defect inspection tomorrow not sure if i will pass,
not too long ago purchased a 5" HKS hi power catback exhaust system for a series 2 R33 gts-25t went straight in un restricted and @ 3,300 rpm it read at 97db but on the side i was only revving it roughly at 3k had a 1-2mm peice of sheet metal with a 30mm hole or so drilled into it so it can restrict the flow... now the exhaust seems a bit loud and it has to be 90db at 3,300rpm any ideas on a quick silence fix i been told to chuck a piece of chicken wire inside?
any ideas much appreciated :)
https://www.sau.com.au/forums/topic/330757-defect-inspection-tomorrow/
unfortunately not =[ dont know anyone with a import or a silencer to fit the huge exhaust the restrictor has quietened it down a bit but i dont think enough need a kinda quick fix as its booked in for 3:30 tomorrow any other ideas sorry for the trouble...
cheers chris
unfortunately that's not another option, purchased the car with a aftermarket exhaust which was sold some time ago and looking for a quick fix... is there something i might be able to insert into the muffler or something along the lines?
you can try creating a small black hole in the tip of your exhaust Im fairly sure I remember reading that nothing escapes a black hole not even sound....
Other than that, no, not on this short notice...
get a steel plate like you have. instead of drilling one 30mm hole drill a few little holes to restrict it heaps. then when ya done take it out :nyaanyaa:
make them about 4mm or 5mm holes and dont do too many, but do enough so it doenst stuff ya enigine
Edited by Nackerz
going to get it done now thankyou soo much
A heap of rolled up chicken wire does the job, not just sitting there lol
The steel plate doesnt just sit there. You make it the same size and shape as the flange on the rear of the cat. Drill your holes through it where it bolts together, and drill some holes through it where the exhaust gasses can flow through :D
not having a go at you, just saying thats how its done.
The steel plate doesnt just sit there. You make it the same size and shape as the flange on the rear of the cat. Drill your holes through it where it bolts together, and drill some holes through it where the exhaust gasses can flow through :)
Oh nah sorry mate, I was replying to Security, not contradicting you again :D your idea should be spot on too
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
