Use the RB25 bracket and RB25 pump, the bracket has to have the top lug cut back level with the bottom two (as all three bolt to the block now instead of two on block one on head like normal RB25).
Just a side note on the pump.. what balancer are you using? if using say an RB26 ATI balancer you'll need to use an RB26 bracket and pump, the top lug still needs to be ground back though.
https://www.sau.com.au/forums/topic/330808-rb2530/#findComment-5372756
  • 4 weeks later...
Y does a 25 pump and bracket need to be used?
i have fitted a rb30 bracket and pump to my build, just had to get a shorter belt. also i am using a ross harmonics metal jacket balancer.
im also using rb30 alternator and n1 water pump. and had no issues with the belt linning up/fitting.
not running aircon.
https://www.sau.com.au/forums/topic/330808-rb2530/#findComment-5410468
I think the main issue is with people using RB26 ATI balancers, the 25 pump seems to sit slightly differently to the 26 pumps.
i.e. I have an R32 RB25DE head and RB20 ancillaries, using an RB26 ATI balancer with RB26 pump/bracket. My mates 25t/30 with the same balancer, his 25 pump didn't line up.
Edited by bubba
https://www.sau.com.au/forums/topic/330808-rb2530/#findComment-5411285
