This car is in excellent condition and has been looked after. you will not be disapointed. Has the usual wear on the steering wheel but the rest of the interior is in good condition besides 2 cigarette burns. It has a very safe tune at 300rwKW. I have over $20 000 in receipts of parts alone. I have to sell this car now so please call for an inspection, 0412591563.
Car is located in Townsville.
Price, $24,990
2000kms on new motor.
block cleaned, checked, decked, only bored 20thou.
Brand new r33 N1 crank
Greddy/trust oil pump
N1 water pump
Arias forged pistons
acl race series engine and rod bearings
Acl race series mls head gasket
Tomei rod bolts
Tomei oil restrictor
Tomei sump baffle
Mines cam cover baffles
ball bearing turbos (N1's)
550cc nismo injectors
bosch 023 800hp fuel pump
sard fuel regulator
Fully rebuilt head, shaved, new valve seals, bronze guides, etc
ported bowls
3 angle valve grind
spool adjustable cam gears
gates racing cam belt
pwr intercooler
splitfire coil packs
Z32 afm's
Apexi Power fc
Apexi turbo timer
Hks evc boost controller
remote mount oil filter, under car (no more spilling oil all over the engine bay)
oil cooler in front guard
External oil drain from head to the sump
synthetic oil only used throughout car.
300rwkw/ 400rwhp on 18psi
Trust dump pipes, trust 3.5 inch collector
3.5 inch cat
3.5 inch exhaust
Blitz twin plate clutch, converted back to push type (originally pull type, I have all the pieces to convert back)
ebc red stuff brake pads in front, jap pads in rear.
slotted dba 4000 series rotors
D2 adjustable coil overs
Cusco adjustable upper control arms front and rear
Cusco adjustable castor rods
Hicas lock out bar
All hicas equipment removed from car, rack, lines ect.
18 x 9 inch xhp wheels 265/35/18 tyres all round
handles like its on rails.
Factory midnight blue colour
Factory bodykit.
Standard interior
Autometer oil and water gauges.
Kenwood 7" touch screen dvd , infinity 6' splits, Focal 6x9's.
post-58160-1280382239_thumb.jpgpost-58160-1280382258_thumb.jpgpost-58160-1280382294_thumb.jpgpost-58160-1280382371_thumb.jpgpost-58160-1280382386_thumb.jpg
https://www.sau.com.au/forums/topic/330819-fs-1993-r32-gt-r-skyline/
Price dropped, $22990
This car has some of the oil issues fixed with the external oil drain for the head, Tomei oil restrictor and Greddy oil pump ( has larger, stronger gears to give more oil flow and pressure as well as a 8000rpm limit. N1 pumps still use the same weak gears as the std pump and only increase the oil pressure not the flow at all as well as only being good for 7500 rpm before failure. N1 pumps aren't much better then std pumps.)
  • 4 weeks later...
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
