Hi guys, just got my car for almost a week now. Before I got my car, I was watching a review of the G35 in youtube and the review was saying the car's suspension is smooth and nice and much better than the 350Z for usual roads.
After 1 week of driving on NZ roads, i note that the car is nice n quiet on smooth tar road. However, when there are more bumpy roads, I note that the car's suspension is quite firm and the noise level is much higher.
Just keen to know what's everyone's experience and verdict for their v35's suspension. Mine is stock suspension + stock Bridgestone Potenza 18 inch tyres.
https://www.sau.com.au/forums/topic/330862-firmness-of-suspension/
I've got stock suspension and stock 18s (45/18 rubber) and I imagine the experience is much similar to yours. The car is exceptionally smooth for what I would have expected. I have a Honda Accord Euro CL9 too which is lowered on Eibach Pro springs and Koni Yellow adjustable shocks with 40/18 rubber and the V35 is considerably smoother over bumps
Yeap, got a coupe too. Smooth road is smooth as. Bumpy rough roads, more road noise and what not, but I don't think it's that uncomfortable?
I came from an s14 lowered, so everything about this car is more comfortable :D
Are you trying to compare it against any particular car?
Coupe has firmer suspension than sedans, so if you're after a totally smooth ride, get the sedan...
The 350gt/gt8 has the same suspension as the 350 coupe, as the spring rates are the same.
I have the GT8 and have fitted a full Nismo set from a 350z, the spring rates are slightly different to the Skyline spec items, .1 kg different front and rear, the ride is still good but the handling is much improved, reduced body roll.
Well I m not really comparing it with other cars. And I did expect the car to have a firmer suspension compare to a sedan. It is a sports coupe afterall. So definitely not complaining n I do feel the ride is great. I guess my only little concern is really the noise level on bumpy road. It's still smooth though just abit noisier. But like I say I m not complaining as I m loving every second I m driving the car.
The main reason I started the thread was just to know how others feel.
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
