Fount 2 wires cut behind intake manifold. pretty sure they are for temp sender, a green and a blue/black wire. looks like there have been cut off a plug, trying to find were they go not having much luck, can some one have a look or tell me were the hook up 2?? might need to pull main loom apart looks like its been taped up may have cut wires in there.
cheers
https://www.sau.com.au/forums/topic/330869-reason-for-bad-start-rb20det/
only wires I can think of which are behind the intake manifold is the plug for the IACV valve (Idle air control valve). Might explain bad start as mentioned in your title?
Take note of the brown plug to the right of the photo. Do you have those wiring? (disregard the red circles)
yes, but why do most rb20's take alot longer to start compared to a 25 or 26?
yea iv got the same wires. the wires cut use to have a connection on it which goes to another connection going to the heater hoses on the fire wall at around the same hight as the wires. mine have been unplugged for years.
cheers
what is it doing to not start properly?
    • @Dose Pipe Sutututu I would argue that >300rwkW inevitably comes only with a raised boost threshold that makes it more likely to get beaten by the family SUV with a 95 speed auto transmission and TD torque. Ditto the traction problems when it finally does come on boost. I used to love my stock turbo. A little flex of the ankle and it made a sweet little whistle and you had torque immediately. It wasn't fast fast, but it was more likely to win the "squirt to make the gap" type races that actually matter for a street car. I think >300 rwkW requires more capacity than an RB25 can offer (again, for street driving). I have enough experience with driving 2JZs in that space to know that they are much easier to pedal around in than a 25. I keep thinking Greg did the right thing putting a V8 is his car. I can't see myself not having a turbo - but I'd really like a big engine torque curve.
    • This is kinda how I see it also. Could drill down then into sub tags.
    • Let's be honest here @GTSBoy 250kW in a GTS-t would easily get walked by my a family SUV these days. 300kW is the sweet spot, fast enough to keep up with the modern German cars (not from a stand still), fun enough and the motor still can be stock/unopened. Realistically, 400kW is a good number. It's enough to give you cold sweats, still be very street able in terms of the power band (provided you're not an idiot and go single scroll and delete VCT) and only needs a very basic rebuild (or stock if you have a NEO motor). Anything more, it starts to be stupid.
    • Deals off now apparently https://www.abc.net.au/news/2025-02-13/honda-and-nissan-say-merger-talks-called-off/104934438 Hopefully Nissan closes up soon and the family X-Trail becomes a classic too!
    • The west where I live is swarming with birds, not wrong they are bloody loud. In the meantime, do a DIY killswitch - $5 worth of things from jaycar, easy as too. The west is copping it with car theft lately, especially the big shopping centres.
