I have a spare set for sale if interested. Almost new with only 500Kms on them. There's about 4 different sets of housings for that turbo. the wrong choice means nothing till about 5k rpm. Different spec for different applications.
The ones I have are good for someone looking to replace there standard turbo's with something that has more but doesn't want the lag to go with bigger turbos.
Sebaz
https://www.sau.com.au/forums/topic/33093-r34-gtr-n1-turbos/#findComment-664550
Can someone please tell me what R34 GTR N1 turbos are rated out? ive ben told they are 250 each by a mate, but im confused as some ppl say when the sell their N1's they are 300-320 hp each
Can any one tell me please
Thanks
M3M3NT0
https://www.sau.com.au/forums/topic/33093-r34-gtr-n1-turbos/#findComment-665829
I have a set for sale. Near new and came off of a R34 GTR NUR spec. comes with the stainless NISMO extensions to suit. $4000 firm. 0409 573 124
Just do a search on the net "R34 GTR N1 turbo".
http://www.splparts.com
this US site list upgrades for the 300ZX (Z32)
Border N1 turbo kit Z32 $4203 US (special order) rated to 550rwhp
HKS GT2530 turbo kit Z32 $3720 US (special order)
I won't list all the details go to the site and read for yourself.
regards Phillip
p.s. I go to the Gold coast Monday through to Friday..you can look see and compare no obligations.
I'll bring the TD06's that I have for sale as well.
https://www.sau.com.au/forums/topic/33093-r34-gtr-n1-turbos/#findComment-666052
R34 N1's are rated 280PS each from memory. THere is only 1 type of N1 34 Turbo. If you need to clearify the model number let me know. I have a set in the garage. There isnt many different housings for the 34 N1 turbo. There is only 1
You may be able to change them but because they are a genuine Nissan Item, how can there be different housings?
Also i think $4,000 for near new ones with Nismo extensions are about the right price.
https://www.sau.com.au/forums/topic/33093-r34-gtr-n1-turbos/#findComment-666741
Its simple.. with the size wheels the N1's run, different housing sizes mean different efficiency curves for the turbo. IE: effects how and when the turbo will spool up to boost and how long it will remain efficient. Yes one "part number" for the turbo. The ball bearing centre and wheels don't change however the housings can be ordered to suit. 4 I believe in total.
I have two sets of N1's and the're different.
Sebaz
https://www.sau.com.au/forums/topic/33093-r34-gtr-n1-turbos/#findComment-669008
Yes the different HP outputs quoted by different people is confusing, but not if you realise that N1 Turbos have different configuration from year to year and above all variations in boost, head work, cams, injectors, manifolds, EMS tune etc. All contribute to a different vehical response, driveablity and output.
BNR32 (NISMO)......Serial No. 14411-06U00 (F/M273 deg. plain thrust bearing centre)
T04B Compressor with a 0.42 A/R and 62T
T25 Turbine with a 0.64 A/R and CD79
BCNR33 (N1)......Serial No. 14411-24U10 (F/M360 deg. plain thrust bearing centre)
T3 Compressor with a 0.42 A/R and 55T
T25 Turbine with a 0.64 A/R and 62T
Included this for information...all R34 GTR's are Ball bearing turbo's...all previous models are only plain bearing.
BNR34 ......Serial No. 14411-AA300 (Ball bearing centre)
C100 Compressor with a 0.53 A/R and 50T
T25 Turbine with a 0.48 A/R and 62T
BNR34 (N1)......Serial No. 14411-AA401 (Ball bearing centre)
BNR34 (N1)......Serial No. 14411-AA402 (Ball bearing centre)
BNR34 (N1)......Serial No. 14411-AA403 (Ball bearing centre)
C106 Compressor with a 0.60 A/R and 55T
GT25 Turbine with a 0.64 A/R and 62T
regards Phillip
https://www.sau.com.au/forums/topic/33093-r34-gtr-n1-turbos/#findComment-669682
The R34 GTR N1's: comparible in size and output to 2530's
*Is a modern design.
*It is a Ball Bearing Turbo. (spools up quicker)
*Has a GT25 Turbine, the same as modern HKS designs....with a built in wastegate divider.
*Will handle a lot more boost.
*Will give great response and streetability.
*Is capible of propelling a GTR into the elevens.
If your after bigger HP numbers.....want to go quicker over the quarter...get bigger twins or a large single.....but be prepared to spend on upgrades everywhere and compromise the street/drivability of your car.
Phillip
https://www.sau.com.au/forums/topic/33093-r34-gtr-n1-turbos/#findComment-669977
  • 1 year later...
I had r33 N1's in my r33 gtr , with full exhaust , power f/c and ebc , everything else stock , even stock airbox , it was good for 11.7 1/4 mile @121 mph .
When i was in Japan i wanted to buy N1's for my r34 but because of the different types of N1's i desided to go hks gtss , they are not in the car yet , i want to run the car stock first .
it is definately possible to get into the 10's with n1 turbo's, i ran 11.18@126 at willowbank
recently with n1's and there is more in the car yet, best part is they have great response from down low in rpm.
cheers russell
cheers russell
Dont forget the 32 is a lot lighter than the r33 too .
Yea the N1's had very good power all the way from 4000 to the cut out .
cheers russell
What power were you making when you ran that time?
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
