Hello Nissan men and women.
I've got an old PC I'm trying to ressurect so I can get my albums and porn off her.
When I turn on said PC, I get a short pause, then I get a beep, 3 seconds long or so. Then a 3/4 second silence, then another 3 second beep and so on.
Does this beep mean a fault code like a f*kn car ecu?
IIRC (I dont currently have a monitor hooked up) with a screen hooked up I get no visuals, cant remember if the monitor goes off stand by or not when this happens, i THINK it did, Ill be trying this soon.
PC is an AMD pentium 1.6 equiv or similer. pretty much dead standard no cool graphics cards or anything.
PS. I un hooked the power switch (on/off switch) and tried another because I couldnt even get it to turn on. changing the switch fixes this. I was gonna change the power supply but thought I'd try that first.
Thank you for your time.
-Dale
-Dale
Depends on your BIOS as to what the beeps are. As far as I remember the long ~3 sec beep was related to either a loose video card, or loose RAM. If reseating them doesnt work, you can try resetting the BIOS with the CMOS reset jumper (requires new BIOS setup, if you don't understand, don't do it yourself). If that still doesn't fix it, you have either some dead parts and/or a bad power supply.
I suggest, if you have another computer, put your HDD into it and get your music and porn off it that way.
+1 the easiest way is to just put the HDD in another computer and not bother stuffing around with the old one
Yes I think I'll just end up doing that. Only problem is the only comp I got here to do it on is my old mans and if I mess that up im screwed. If I follow a guide off google say on installing it as a slave drive will I have any untowards problems because it has its own OS on it and what not??
if you don't know what you're doing, get someone else to do it (ie putting hard disk in another computer).
Chances are in a computer that old, it's an IDE hard disk, most modern computers have done away with an IDE controller completely in favour of SATA (depending on chipset etc)
Most new motherboards have at least 1 IDE port in my experience. Worst case scenario like Boz said ask someone who knows what there doing to help out.
as I said, depends on the chipset, anything with a non cheap shit mobo (and even the Dell Optiplex post GX 620) dosen't have IDE.
OP: if you're not confident, have a look through youtube, it showed me how to replace the hard disk in a 24" Imac, and it still worked when I finished :D
OP: if you're not confident, have a look through youtube, it showed me how to replace the hard disk in a 24" Imac, and it still worked when I finished :bunny:
The new Asus boards still have IDE. For instance the Asus M4A89GTD PRO still has it. That isnt what i'd call cheap shit.
well I dunno what this guy's dad is running, but it would be fairly safe to assume it's not running a name brand mobo. In addition that is a low end example; from what I've seen the cheaper chipsets with integrated graphics etc tend to have more legacy features like that.
True, true Boz. Its probably something on the cheap side even it is a name brand. Chances are it has IDE like you say, worst case scenario IDE cards can be had for $20 at the local computer shop.
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
