Does anyone have any force velocity graphs of dampers installed on their Skylines?
I am trying to work out what damper rates would be suitable for a spring change & am having trouble getting any decent information out of the suppliers. If you could make mention of the spring rates they go with that would be great.
https://www.sau.com.au/forums/topic/330935-damper-graphs-wanted/
Good luck with that. Really, the only way you're going to get that info is if you have a friend with a shock dyno and can convince a bunch of people with the same car as you but also with all different types of shocks for you to remove from their cars and test on the shock dyno. Not likely.
Why do you feel you need to be so scientifically specific when it comes to shocks, there's a bunch of excellent options straight off the shelf that any suspension shop worth their salt should be able to match up to suitable springs for you.
I am manager at City Suspension in Brisbane and can discuss it with you if you want to give me a call at the office during the week, 3808 3266 ask for Tim.
Edited by BI6TIM
The point is that once you have calculated the damper rate for bump & rebound and worked out the acceptable range on what you want for both ends of the car it would be nice to be able to tell by a means other than the usual salesman blandishments that the shocks are, infact, what you are after.
The information is not unknown or even unavailable. It is not a case of being so scientific, simply a case of being able to select a shock using some basic information.
The suspension shops match springs to cars & to dampers. But htey do so in such a broad range that makes me less than 100% comfortable with the selection.
Anyway, love to all, etc. :)
I'm in the same boat, post any findings you get djr.
As much info I have at the moment is as follows. The numbers are based on the sprung weight of my car & hence will be different for others, obviously.
Stock R32 GTR info:
Front spring rate 2.4kg/mm & damper rate based on 0.3m/sec - assumed to be linear
Front bump damping ratio 0.25 (500N)
Front rebound damping ratio 0.89 (1746N)
Rear spring rate 2.7kg/mm & damper rate based on 0.3m/sec - assumed to be linear
Front bump damping ratio 0.24 (402N)
Front rebound damping ratio 0.66 (1108N)
Nismo R32 GTR info:
S tune damper set to the middle of 5 settings.
Front spring rate 5.5kg/mm & damper rate based on 0.3m/sec - assumed to be linear
Front bump damping ratio 0.36 (1079N)
Front rebound damping ratio 0.64 (1912N)
Rear spring rate 4.5kg/mm & damper rate based on 0.3m/sec - assumed to be linear
Front bump damping ratio 0.32 (686N)
Front rebound damping ratio 0.63 (1373)
Notes:
A reduction in srpung weight gives you an increase in damper ratio.
An increase in spring rate gives you a lower damper ratio.
What is deemed acceptable for bump & rebound ratios for the front & the rear is arguable. I am presently chasing some info from some of the damper manufacturers but who knows if they will come good.
try calling suspension technology australia in yass, nsw. for the reasons you're stating i had jap ohlins, bilstein pss9, sydneykid bilsteins, and konis both original and revalved dynoed there. john also had graphs of teins that from memory came off a 32 gtr. he's a font of knowledge and very good with this stuff. he used to work for eibach and has been in the game for donkey's. did brock's targa monaro suspension too. unfortunately i don't have the graphs anymore but he could prob be persuaded to part with the info.
good on you for going down this path, too. i've found once you decide to ask the really hard questions about what you're spending money on, and decide to do some research to get to the real truth with these things, the information dries up unless you persevere and get it yourself but it's worth it.
Edited by Scooby
Yes cheers. The have some good systems. I think (from memory) that getting them to go through the sheets for your car was well priced & that getting the dampers dynoed was equally good value. Just out of interest did you get them to produce a set of sheets for your car?
As for the second paragraph that is exactly what frustrates me in trying to modify a car. I don't reckon the questions are actually very hard but it doesn't mean they get answered.
lol your are spot on there djr. the questions are really basic, no-brainers even, but it's frustrating when no one knows the answers to the fundamentals and even more frustrating to think that people in the industry haven't bothered to find out. try getting empirical evidence on the often quoted RB30 harmonics issue or the benefit of dump pipes. i can't really blame the industry though, research does cost and if people are prepared to part with their money...
you prob know this but if you want to see whether a susp guy is thinking, ask what sort of bumpstops they use and why they chose that elasticity. if they use the term 'universal' ask how they can use the same units on a GTR as on a Civic. that's the thing with john, he has prob 20 different types because he understands the importance and with limited travel the 32 needs some thought in that area.
STA did produce graphs for the dyno, if that's what you mean. can't remember the cost but it was well worth the $ to know, particularly when i found that one set with 36 click adj only worked from click 25 onwards. imagine the stuffing around that saved in terms of trial and error.
Edited by Scooby
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
